Author Topic: Fork in the road with my Rebuild  (Read 3358 times)
Offline Shalka04
« on: May 23, 2012, 11:32:46 PM »
First of let me say I know my T-90 is now Ford Blue, it's just that I wanted to be able to spot any sort of leak or drain, and the satin black of everything else just wasn't doing it for me.
So i'm at a pause trying to figure out what the next major step in my rebuild should be. �Do I install the tub next then the engine or engine now and tub later. �Then again does it even matter?
Thanks for your suggestions,
-John
Re: Fork in the road with my Rebuild
« Reply #1 on: May 23, 2012, 11:43:18 PM »
I would put everything I could on the frame before putting the tub on and that includes the steering box.
« Reply #2 on: May 24, 2012, 01:35:08 AM »
I agree with Carl. �However, it's your Jeep and you can certainly assembly it as you like, but I would suggest installing the entire drive train and test driving it thoroughly before covering it all up with the tub and fenders. �Much easier to work on if you discover a problem. �
I installed brake lines and hoses, clamps, etc., before the engine was in the way. �
Then the complete drivable rolling chassis was test driven for more than two hours before fitting the tub, fenders, grill, and hood.
Then the tub, fenders, and all were completely assembled. �This allowed for all cutting, grinding, and welding to be done before painting. �
That's the only way I learned that I had to modify the tub opening for the transmission.  Would have hated to do this after paint.
After the test runs, body fitting, and painting, the final installation of the tub and other components took place.
« Last Edit: May 24, 2012, 01:44:27 AM by calvinhunt »
« Reply #3 on: May 24, 2012, 06:29:13 AM »
I had to pull the transmission and the steering box several times after the initial "rolling chassis" test drives in order to chase leaks and other problems. It would have been a nightmare if the tub was on. As an added bonus, being able to actually drive the thing well before completion was a blast.
« Last Edit: May 24, 2012, 06:34:13 AM by Ryan_M »
« Reply #4 on: May 24, 2012, 11:23:28 AM »
Calvin, your looking mighty sharp on that Hot Rod Jeep there fellow. ;) 8-)
« Reply #5 on: May 24, 2012, 03:21:12 PM »
X4 with all the replies above.  If you have done ANY bodywork or used ANY reproduction parts, you are going to have to assemble everything to ensure a proper fit.
Also, you get some of the best looks when you drive around with nothing but a frame, motor/tranny and wheels  :o
Offline BMIC
  • Weekend Mechanic
« Reply #6 on: May 24, 2012, 04:02:07 PM »
John great job so far... I kinda like that blue.
« Reply #7 on: May 24, 2012, 04:05:14 PM »
I think a white skid plate with blue transimission mount and crossmemberr would add the "Patriotic touch"!!
Offline CJPilot
  • Shade Tree Mechanic
« Reply #8 on: May 24, 2012, 08:57:38 PM »
John �You are certainly �moving along at a good clip! �Looks like you�ll be done in no time at all. �I plan on putting everyhing I can back on before I mount my tub.
Steve
1950 CJ3A
