Author Topic: Fuel issues  (Read 10894 times)
Offline rocketeer
  • Support Our Troops.
Re: Fuel issues
« Reply #15 on: May 20, 2012, 02:01:41 PM »
Which outlet do you consider to be the drain? Is your line connected as shown in the photo?
Re: Fuel issues
« Reply #16 on: May 20, 2012, 09:58:32 PM »
Saw,
I agree with Larry(Rocketeer)  Pictures say a thousand words. �You would be surprised what the members here might see that may help solve your issue.
Besides, you live in Colorado. �I live in Colorado (Arvada). �If I ever see your Willys on a drive, I'll know who I'm chasing down.
« Last Edit: May 20, 2012, 09:59:31 PM by athawk11 »
Offline SAWCo69
  • 462a,503a,73cj5,75cj5,533a
Re: Fuel issues
« Reply #17 on: May 21, 2012, 08:48:16 AM »
Did take some pics on Sunday , but can't seem to post them.
Sundays test flight ended in failure, dead jeep by the side of the road.
A bit of a bus ride, a walk and then towed Little Red home.
Stay tuned....
Maybe someday I'll get them all running
Re: Fuel issues
« Reply #18 on: May 21, 2012, 11:51:31 AM »
Posting pictures is a bit of a challenge...but nothing like the challenge you are facing with your Willys.
The easiest way to post is to us a secondary photo site like www.Photobucket.com
It is free...you can easily download your photos there...then from there, you can move them into your post.  There are some posts on how to do this, but some still seem to have trouble.  Could be an Internet Explorer or Firefox thing.
Look in the Web Site Feedback area for help.
Offline calvinhunt
Re: Fuel issues
« Reply #19 on: May 21, 2012, 05:26:07 PM »
Installed 5/16 hose barb in tank drain, ran fuel line up to engine.This will be my back up fuel line if the other still won't act right. Added a elec. fuel pump to the jeep tool box, some wire, and set out on another test flight.
 ï¿½1 1/2 hours of good jeep driving... � ...sputter, cough, die....dead red jeep by the side of the road.
 ï¿½Unhooked original fuel line from pump, jammed fuel hose from tank drain on and fired right up......drove home bewildered.
Did you hook up the electric fuel pump as you switched to the use of the 2nd fuel line (the backup 5/16 fuel line you installed in the tank drain port) or just drive home on the backup fuel line?
A friend has a CJ-2A that I drive from time to time. �He has an electric fuel pump installed in the fuel line just down stream from the fuel tank. �That Jeep acts strange. �It will drive for 30 minutes to an hour with the elec fuel pump off without hesitating, up hills as well. �Then it will sputter, cough, and die. �It will not start unless you turn on the elec fuel pump. �Turn on the pump it starts instantly. �The owner just drives with the in-line fuel pump always on. �It never dies. �Sounds like that may be a solution.  I don't know what the answer is.
« Last Edit: May 21, 2012, 05:29:06 PM by calvinhunt »
Calvin
Santa Clara, Utah
Offline rocketeer
Re: Fuel issues
« Reply #20 on: May 21, 2012, 07:10:54 PM »
It sounds to me like a vented cap problem but we're not getting specific answers, info or pics so it's difficult to judge.
Offline SAWCo69
Re: Fuel issues
« Reply #21 on: May 21, 2012, 08:11:27 PM »
Sorry about the lack of specific answers, info or pics, my current level of frustration with the 50 is spilling over into my computer use......
 1.) Drilled a hole in a fuel cap, stuck a 1" chunk of brake line thru it, instant OSHA approved, vented for sure gas cap.This was installed before the last test flight.Did not seem to make a diff.
2) Have not hooked up the elec. fuel pump yet ( the backup line from the drain seemed to work on test flight #1, but not yesterday on test flight #2) plan to install elec pump in backup line and try.Bit worryed about too much presure for Solex carb,not sure if I'll need a presure reg.
3.) Will get pics up sooner or later.
4.) Thanks for the encouragement.
5.) Athawk11, I'll be the Dead Red 50 Willys by the side of the road.
Offline SAWCo69
Re: Fuel issues
« Reply #22 on: May 21, 2012, 10:30:31 PM »
Did manage to post some pics in the Web Feedback thread, can't seem to doit here....
Offline rocketeer
Re: Fuel issues
« Reply #23 on: May 22, 2012, 09:53:07 PM »
Can you take a pic that shows the whole area from the pump up to the carb including the fuel line?
« Last Edit: May 22, 2012, 09:54:59 PM by rocketeer »
Offline SAWCo69
Re: Fuel issues
« Reply #24 on: May 23, 2012, 08:23:47 AM »
Posted a pic of fuel lines from pump to carb in Web Feed Back thread
Sorry, but still can't get any posted in the Tech Section.
Rocketeer, thanks for finding my pics and moving them......
Offline rocketeer
Re: Fuel issues
« Reply #25 on: May 23, 2012, 08:44:43 AM »
Upon seeing this pic, the first thing I would advise is to install a correct metal line all the way up to the fuel pump, with a correct short flexible connection. It's never a good idea to use soft line on the input (suction) side of a pump. A long rubber hose like that has a tendency to suck closed, especially after heating up from the engine.
Re: Fuel issues
« Reply #26 on: May 23, 2012, 11:09:33 AM »
Hey Larry,
I think these photos may be showing his temporary fall back approach.  A prior post mentions the 5/16" fuel line from the tank drain to get him down the road when he has issues.  Looks like there is a steel line connected to the tank in the right position, but I can't see how long or how far the steel line travels before it reaches the engine compartment.
So...Saw,
As Larry points out, the original set up is steel from the front hole in the tank until it is within about 6" from the pump.  It then has a short rubber connection to the pump.  It was done this way to give the line some flexibility between the engine movement and the more rigid chassis and fuel line connections. It reduces the chance of a fuel line break.
So, on your standard original setup, if you have a long rubber line attached to a short steel line, Larry's thoughts are true.  (By the way, Larry's thoughts are always true.)  Upon heating up, the rubber could compress under pressure from the pump.  Similar to what happens on an older lower radiator hose that causes overheating.
Ther routing of the line from the pump to the carb looks good.  Good and far away from the manifold heat.
I read in another post that if the cam shaft has movement, the arm on the pump can slip off the lobe and cause the pump to stop pumping.  Could this be a factor?
Offline SAWCo69
Re: Fuel issues
« Reply #27 on: May 23, 2012, 09:22:04 PM »
Yes, this pic shows the fall back rubber line that goes to the tank drain.
  I installed a set of orginal steel lines,back when this all started. If you look closely you can see the short rubber flex hose (with a bolt plugging it) that I substituted for the orginal flex line, the orginal screw-on flex line was about 1 1/2" too short, so I installed a hose barb on the suction side.This makes changing the lines much easier when I'm broke down by the side of the road....
   Today I installed an elec pump near the tank, on the frame rail.The rubber line is then connected to the suction side ofthe mech pump.Thinking is that the cam operated pump will pull fuel thru the elec pump, if the mech pump won't pump I switch on the elec and the mech pump will act as a pressure regulater.
  This seems to work in the shop........on the road may be another thing.Raining to hard for a test flight.
  Really would like to take the jeep camping in Brown's Park this weekend.It went last year and was a big hit, of course that was the last gasp for the engine, current rebuild being the result.But Brown's Park really is past the middle of nowhere,bad place to break down. Not a lot of confidence in the jeep right now.
Thanks again
Offline rocketeer
Re: Fuel issues
« Reply #28 on: May 24, 2012, 06:32:08 AM »
I give up. When we finally get pics they aren't current. How the heck are we supposed to help? I'm out of this one.
Offline Carls_jeep
Re: Fuel issues
« Reply #29 on: May 24, 2012, 11:20:20 AM »
When your trouble shooting a problem you can't use a shotgun approach. You have to stop and think the problem out. To get it home use what ever method you can but when you approach the trouble shooting method it has to be organized and systematic. Once you start pulling things apart you may have destroyed any evidence your looking for.
I was an engine failure trouble shooter at a Cummins distributor and learned early on to be careful and find everything I can before tearing an engine down. Once the engine is disassembled your testing is done and everything is visual from there out.
To many times people start tearing something apart without knowing what they are looking for or having a plan.
