Author Topic: engine oil priming update  (Read 2817 times)
Offline Macgraham
« on: May 05, 2012, 07:08:41 PM »
I tried the grease gun idea to prime my 134 oil system and it really worked well. First thing it told me was that I forgot to put the plug in the oil filter can. Took longer to clean the gun than to put the 4 quarts in. It also told me that I had a leak in the oil pan. One of the spot welds had cracked where the guard was spotted on. Fortunately I had another pan that is good so no better time to do it than now. When I dropped the old pan you could see that the bearings had lots of oil from the grease gun pump, lots o[IMG]http://i106f oil dripping down.<a href="http://
« Last Edit: May 05, 2012, 07:49:08 PM by Macgraham »
Re: engine oil priming update
« Reply #1 on: May 06, 2012, 07:44:51 PM »
 ;D don't you love it when one thing after another starts pulling your rope. How many times did you have to fill the grease gun with oil to prime the galleys?
Offline Macgraham
« Reply #2 on: May 06, 2012, 10:33:56 PM »
Imust have filled the gun 5 or 6 times. I tried to send a photo but it didn't work. Will email it to you Carl.
« Reply #3 on: May 07, 2012, 01:25:24 AM »
Mac sent the photos of his grease gun application for priming his engine to me, as well.  I posted them here without his permission.  Hope we're still friends.
« Reply #4 on: May 07, 2012, 01:18:05 PM »
Your Jeep is looking good and I do like the pressure lube system.
Offline CJJay
« Reply #5 on: May 15, 2012, 01:25:13 PM »
This is cool, I was thinking about useing the line from the top of the oil canister to force the oil into the pump. Do you think this will work as well?
Offline Macgraham
« Reply #6 on: May 15, 2012, 01:39:45 PM »
I think this worked really well. I had to drop the pan because of a spotweld leak right after I finished priming and there was oil dripping down from all the lower bearings. It also filled the oil filter can. It would probably work the way you describe as well if you can close up the system.
Offline CJPilot
  • Shade Tree Mechanic
« Reply #7 on: May 15, 2012, 03:08:41 PM »
Mac �Good way to prime! �I have used a small pump up sprayer from a box store to do the same. It worked very well.
Steve �
1950 CJ3A
