Author Topic: Rear Axle tools?  (Read 1591 times)
Offline Shalka04
Rear Axle tools?
« on: May 02, 2012, 09:10:28 PM »
I figure as part of my rebuild I should check the brakes and repack the bearings.  That being the case can you guys help me with a list of what "special" tools I may need.  If I have to buy it or build it I'd like to know ahead of time.  I lost 3 days pulling my steering wheel and don't want to run into another one of those.
-John
Re: Rear Axle tools?
« Reply #1 on: May 02, 2012, 10:21:12 PM »
You will need a brake hub puller, all the rest of the brake job is done with standard hand tools.
Were you able to get the steering wheel off without destroying it?
« Last Edit: May 02, 2012, 10:22:04 PM by Carlsjeep »
Offline captnjody
  • '51-3A, Johnny Reb
« Reply #2 on: May 03, 2012, 08:59:24 AM »
Make it easy on yourself, find a brake adjustment wrench. The adjustment studs can be a pain without a slotted wrench. i have bought several on Ebay, and it sure makes life alot easier.
1951 CJ-3A �"Johnny Reb" #451-GB1-27065
'48 bantam T3-C
'70 deuce
