Author Topic: Touch the throttle, it dies  (Read 2484 times)
Offline Comanche_County
« on: May 02, 2012, 04:28:12 PM »
Okay, the 50 is starting good, idling well, then you try to open the choke, it dies. �You give it a bit of throttle, it dies. �It'll idle along in gear, then shift to second, give it some gas, it dies. �
It does this with the old WO as well as the new Solex. �
All the ignition except for the distributor is new. �I've got good spark. �The plugs are a little sooty but that shouldn't be it IMO.
Battery is new, the generator is iffy sometimes. �
Possible culprits: �Mechanical advance in the Dizzy? �Dizzy shaft play? �Although its not too bad IMO. �Do I have this thing completely timed wrong? �I've got #1 set right after TDC on the compression stroke. �Bad grounds? �But I've added two extra ground straps, engine to firewall and battery to rad support.  The tank is a bit rusty, I'm getting flakes in the fuel filter.  I've done a mild cleaning on both carbs and still no change.
Last week I was driving this puppy around, now, no joy.  I put about 50 miles or so on it without an engine issue.....If I don't figure this out, I'm going to have a heart attack, and I'll die, If I do someone please dig a big ole hole and bury me in a Willys.
« Last Edit: May 02, 2012, 04:29:52 PM by Comanche_County »
Re: Touch the throttle, it dies
« Reply #1 on: May 02, 2012, 04:35:50 PM »
Next time it dies so a little investigation... Check for fuel in the carb bowl...It sounds like there is a fuel supply issue. If your carb can't get enough fuel to supply the engine, it will stall. Check for things like �rust or dirt plugging fuel lines, no tank venting, , bad filter or pump.
On your timing.....most times you set the initial timing at a certain number of degrees BEFORE top dead center, not after. You may have timing severely retarded, and need to advance it
You may also have a large vacuum leak....gaskets, cracks in manifolds, bad PCV or missing valve, etc..
« Last Edit: May 02, 2012, 04:38:01 PM by F_Bill »
« Reply #2 on: May 02, 2012, 05:03:35 PM »
Comanche,
I'm with Bill on this one.  Sounds like fuel delivery to me.  Especially if if was running fine before this most recent problem.  I had a recent similar issue.  Climbing a hill, hard on the throttle, my engine sputtered.  The minute I got off the throttle it ran fine.  Turns out, there was a good sized chunk of crud blocking my fuel filter intake. (fuel filter has a glass housing)  I put in a new filter and the problem was gone.   My fuel system just couldn't deliver what the Willys was demanding.
You could have a chunk you can't see.  I was fearful of what might have been in my old fuel lines.  I replaced them all, just in case.
« Reply #3 on: May 02, 2012, 08:23:05 PM »
Thanks for the tips and advice, as usual fellas!
I got it going just a few minutes ago.  Took it around the block and it ran just fine.
Bill, AT, I checked everything you mentioned.  The PVC valve was clogged, got that cleaned up, also blew out the hard line to the tank.  I believe the culprit was very small bits of rust clogging the carb and the fuel pressure regulator.  Cleaned out both and rechecked the timing and all ignition components.  BTW, the fuel pump works great, psi is low in my uneducated opinion, but volume it there, it puts out a lot of gas, more than the engine can burn I'm certain.
Bill, I hear you on the timing. I'm adjusting the timing by turning the distro to where it starts easiest and then listening closely to where it idles and revs the smoothest.   But when I crack the distro cap, it just seems to alway come out right after the point where I get the compression blowing past my finger in the spark plug hole.  I guess its not a precise way to gauge TDC.  But I've got it where it seems to run the best.
I'm chalking this one up to a rusty tank,,,,definitely needs a new one.
Thanks fellas!
