Author Topic: New CJ3A  (Read 2133 times)
Offline CJPilot
  • Shade Tree Mechanic
New CJ3A
« on: April 25, 2012, 09:40:34 PM »
Hi. I�ve been lurking here a bit and I ended up buying a 1950 CJ3A the other day. �It kinda sorta runs and drives, but not very good. �I'm going to start fixing up the obvious and try and get it to the point of being able to use it in back of my property. �The body is rough and will need to be addressed later. �I tried posting a picture but had zero luck.
Steve
Re: New CJ3A
« Reply #1 on: April 25, 2012, 11:01:22 PM »
Hi Steve.
Welcome to the site. �And thank you for rescuing another old, beautiful Willys Jeep. �It is very frustrating at times, but incredibly rewarding to breath life back into an American Icon.
If you poke around, you know how much people here like photos and any data you can share about your Willys. �I will ask: �What is the serial number on your data plate?
To post pictures, you will need to first post them at a site like www.Photobucket.com �It is a free photo hosting site. � Read through the posts in the below link. �It may help you with the process.
http://cj-3a.com/forum/YaBB.pl?num=1296834876  If this post doesn't help I'll try to give you some step by step instructions.
Once again, �welcome. �You won't find a better bunch of folks with incredible levels of knowledge.
« Last Edit: April 25, 2012, 11:08:16 PM by athawk11 »
Re: New CJ3A
« Reply #2 on: April 26, 2012, 09:24:44 AM »
Hi CJPilot, I saw the photo's of your Jeep on the CJ2 site and it looks ok to me. If your going to use it for fun don't go over board on restoration. Do what is needed to make it safe and mechanically solid and any body work you feel is needed. If you have a title get it registered so you can take it on the road if you want to. If you don't have a title you probably can get one depending on your state laws. Sometimes it takes a little work but you probably can get it titled.
Offline CJPilot
Re: New CJ3A
« Reply #3 on: April 26, 2012, 03:06:13 PM »
Carlsjeep - It looks better in pictures than it does in person. �I'm working on the title. �The last couple Bill Of Sales had the wrong manufacture date so I�m going down a road I�ll most likely end up regretting by trying to get a title with the correct date on it. �We�ll see. �
It ran real bad but I have figured the timing out. .Somebody put the �distributor in 180 degrees from normal, then somebody put new wires on and must have tried for a long time to get it to run right. �They ended up with the firing order 1234 but with the wires one hole off on the cap. �It ran on 2 cylinders . 2 and 3 if I remember right. �
I�m on to the carburetor now, which had about half an ounce of water in it. How it ran at all is a mystery to me
Steve
Re: New CJ3A
« Reply #4 on: April 26, 2012, 05:19:26 PM »
My name is Todd, and I'm a jeep aholic..... Welcome Pilot!  We're all pullin for ya !
Todd
