Author Topic: priming engine oil system  (Read 1814 times)
Offline Macgraham
« on: April 23, 2012, 08:49:14 PM »
I am about to start my L134 for the first time since it was overhauled in 2004. I am planning on using a grease gun which has been cleaned and screw the gun hose 1/8 in. pipe thread into the oil pressure guage outlet. Then I would pump engine oil into the oil system. I think I can put all 4 quatrs in this way if necessary but it probably isn't. How about some feedback to see if I am on the right track and not getting ready to harm the engine. Thanks.
Re: priming engine oil system
« Reply #1 on: April 23, 2012, 08:54:12 PM »
Sounds like a good plan to me.
Offline Shalka04
« Reply #2 on: April 23, 2012, 10:23:27 PM »
I'm in the same boat so to speak, except my rebuild hasn't been started since it was put together in 1990.  I like your idea but was also thinking of getting some oil onto the valves via the pcv opening on the valve cover.
« Reply #3 on: April 23, 2012, 11:18:33 PM »
When I did mine we put assembly lube in the oil pump, just packed her full, then filled the oil reservoir, left the switch off pulled the spark plugs out and turned the engine over until pressure came up on the gage, then we started it.  I've never done one that sat as long as yours has, that may be different.  I have heard that assembly lube will lube the engine for 3-5 minutes with out oil flow, but I wouldnt trust that any of that is left in those old rebuilds.  Injecting it might be a pretty good idea.
« Reply #4 on: April 23, 2012, 11:34:20 PM »
That is the best idea I have heard all day! (If your grease gun works with oil) .........I just might steal that one.
