Author Topic: Original Paint Color  (Read 2960 times)
« on: March 31, 2012, 11:32:42 PM »
I am trying to determine the original color of my '51 3A. It has been repainted at some point but the original color is still visible in several places. I think it is some type of grey but almost looks a little green-ish. I've found various "paint chip" documents online but some of the info seems conflicting. Does anyone know if Potomac Grey and Chesapeake Grey were both used in 1951? The only green color I've found is "Cypress Green" and that isn't what I have. Was there another green? I need to decide a paint color pretty quick and was hoping to go with what my Jeep had when new. I would color match what is on the tub but I'm afraid it may be faded and not an accurate match to what it looked like 60 years ago. But then again, after seeing Garage Gnome's recent pics I may just go with a screaming bright red. ;)
Re: Original Paint Color
« Reply #1 on: April 01, 2012, 08:28:51 AM »
Haha, thanks! It looked more maroon in the paint chip book.
Mine used to be saber rouge originally based on the '53 chart.
Have you looked through the paint chips here: http://www.cj-3a.com/willys_paint_chips.htm ?
If you have a DA, put a real fine disc on it a grind down the paint. that should give you a good idea of what is was.
« Last Edit: April 01, 2012, 08:30:49 AM by garage_gnome »
« Reply #2 on: April 01, 2012, 08:35:15 AM »
I DA'ed my original hood to see what it was.
You can see the primer, the original color and all the other ones it used to be.
« Reply #3 on: April 01, 2012, 09:03:26 AM »
The paint charts usually show all the colors for all the Willys vehicles. CJs were only available in some of the colors listed. Looking at the 1951 paint chart from The CJ-3A Page http://www.cj-3a.com/willys_paint_chips.htm you can see that regular 1951 CJ-3As were only available in Luzon Red, Potomac Gray or Emerald Green.
With that said there are always exceptions. Willys did paint CJ-3As other colors because the dealers complained about the limited color choices. So, the safe bet for 1951 is Luzon Red, Potomac Gray or Emerald Green, but other factory colors are possible.
« Reply #4 on: April 01, 2012, 05:45:39 PM »
I'll probably just go with Potomac Gray although I've seen other 1951 paint charts that show only Chesapeake Gray and no Potomac. Not super critical but figured if I'm going to do it I might as well try and get it right.
« Reply #5 on: April 01, 2012, 10:19:49 PM »
The Potomac River runs into the Chesapeake Bay, I wonder what's the difference in color? �;D
Seriously, if you find a link to the 1951 chart without Potomac Gray I'd like to see it.
« Reply #6 on: April 02, 2012, 07:20:05 AM »
There is a "Ditzler" card on ebay right now that has Chesapeake but no Potomac. I suppose that's an aftermarket card, though, so probably not real reliable. Here's a link to that card anyways:
http://www.ebay.com/itm/Paint-Chips-Ditzler-1-Willys-1950-1951-/370577678700?pt=LH_DefaultDomain_0&hash=item564826a16c
« Reply #7 on: April 02, 2012, 11:27:14 AM »
Lots of times the paint makers would save money on their paint chip charts by not including colors that are the same as the previous years color mix.
« Reply #8 on: April 02, 2012, 08:23:09 PM »
All these paint chip charts are from the paint suppliers and not from Willys. That Ditzler card on eBay does list Potomac Gray at the bottom.
« Reply #9 on: April 03, 2012, 12:01:59 PM »
Ah, thanks Bob. I was reading it incorrectly. I thought it meant Potomac Gray was for '48-49 exclusively but now I see that it is referencing those years in addition to '50-'51.
