Author Topic: Oil pressure line question  (Read 1613 times)
Offline dluyk
  • Now what do I do?
« on: March 12, 2012, 08:39:20 PM »
Took the CJ out for the first run of the year today. Seems to be leaking a bit of oil
from under the 90 degree fitting - I have a feeling it's been doing this for a while.
Any fixes - or would you suggest I just replace the fitting and oil flex line gauge?
By the way - we worked on the rear breaks this winter and all the input you provided was very
helpful. And it stops!! a bit faster.
Uploaded with ImageShack.us
Re: Oil pressure line question
« Reply #1 on: March 12, 2012, 09:06:01 PM »
I would put some thread sealant on it. DO NOT use teflon tape. Small amount of pipe dope should do the trick.
« Reply #2 on: March 12, 2012, 10:09:39 PM »
If you do decide to replace the flex line DO NOT buy a foreign made one, they dry out and crack in short order. Walck's has the good ones.
