Author Topic: dipstick tube  (Read 2444 times)
Offline Macgraham
dipstick tube
« on: February 09, 2012, 01:05:02 PM »
Just getting engine ready to install, the dipstick tube seems to be fairly loose fit. Is there a way to seal it since there is no place for an o-ring? It came from another 134 so I thought it would be ok. Any suggestions?
Re: dipstick tube
« Reply #1 on: February 09, 2012, 02:33:08 PM »
Mac,
I used Permatex 2.  It's a plyable, non hardening seal.  Worked fine.  I also used it on my spines at the transfer case, and to seal threads on the bolts.
Offline p3ferris
Re: dipstick tube
« Reply #2 on: February 09, 2012, 09:33:14 PM »
Just push it down and fasten the clamp tight.
Offline turkehunt
Re: dipstick tube
« Reply #3 on: February 19, 2012, 04:00:14 PM »
I have the same problem with no clamp @ the top The permatex 2 Sounds good  :)
Offline Jesse
Re: dipstick tube
« Reply #4 on: February 21, 2012, 10:04:40 PM »
I took a rounded over punch and put a few indents from the inside out on the bottom edge. Not huge dents, just 3 or 4 small ones for a tight fit. I was able to tap it in with a block of wood on the top and it is holding fine.
-Jesse
« Last Edit: February 21, 2012, 10:15:54 PM by Jesse »
Offline Macgraham
Re: dipstick tube
« Reply #5 on: February 21, 2012, 10:36:41 PM »
I took a socket which fit into the tube snugly and held it in the vise and worked the tube on and off and sideways and it made a good snug fit with the block. It worked out real well. thanks for you're help.
