Author Topic: Painting the frame  (Read 8527 times)
Offline mrman5917
  • 1950 Willys CJ-3A S/N 45360
Painting the frame
« on: February 07, 2012, 02:54:03 PM »
Hello everyone,
I just got my frame back from the sand blasters, and I'm wondering what I should do about painting, specifically if I should do it my self or send it out to be done. I've got to clean up under the outriggers and remove a few more misc parts, and maybe clean up a few areas that were missed in the sand blasting process, but other than that, I'm ready to go.
I don't have a real way to do a paint booth and spray it myself, so rattle can primer and maybe brushed on POR15 with a topcoat or Eastwood Chassis black was what I was considering.
What are your thoughts and what have you done with your project?
Kurtis
Offline Matto
Re: Painting the frame
« Reply #1 on: February 07, 2012, 05:56:02 PM »
Kurtis, That frame looks so nice I'd clear coat it! ;)
Brushing on frame paint is a little time consuming but still looks great.  Redtree makes a disposable chip brush called The "Fooler". These are extra thick, will lay on a nice coat of paint, and you can pitch them in the trash when your done with each coat. Before you start to paint, blow the loose bristles out with your air nozzle. Here's a link to a site that sells them.
http://www.wholesalemarine.com/p/RTI-10005/Redtree+Fooler+Disposable+Double+Thick+Chip+Brush.html
Matt
Offline mrman5917
« Reply #2 on: February 07, 2012, 09:48:19 PM »
What about types/brands of primer and top coat? One easier to do with limited space but lots of time over the other?
Kurtis
« Reply #3 on: February 07, 2012, 10:13:26 PM »
If you go the POR15 route, it goes on 1st, then primer.
Offline mrman5917
« Reply #4 on: February 07, 2012, 10:18:16 PM »
So if I go POR15, it's just straight POR15 then a topcoat for UV protection. If I go with something like Eastwood Chassis Black, prime then paint.
Has anyone used the POR15 Chassis Coat product? Looks like POR15 can be used as a primer for rust encapsulation (not that there is much left:) ) and then Chassis coat goes on top. Seems like an easy process to complete...
Kurtis
« Reply #5 on: February 07, 2012, 10:20:32 PM »
Kurtis,
I studied for weeks and narrowed my choice to POR15 and Mastercoat Silver.
Check this out.
http://www.masterseriescoatings.com/index/primer/
Read the spec sheet and tips. �They make it sound nearly perfect for these old Jeeps.
I used the Mastercoat Silver for my frame, axles, drive train, engine, springs �and my entire tub. �You can brush or spray it.
I picked it because it seemed more user friendly than POR15 and was about the same price. �You can use any primer or top coat over it. (After the Silver, I painted the frame red oxide, then Olive Drab) �
 You can also use it during cold weather months, which was very helpful for me.
I am completely impressed with this primer. �Gasoline ate through my top coats (tank leak). �It did nothing to this stuff.
There are reviews out there on POR15 that ultimately scared me off. �And though, Mastercoat is newer to the automobile restoration industry, I could not find anything negative about it at all. �Trust me, I tried. �After sandblasting my own frame, I did not want to ever do that again.
Good luck.
Offline mrman5917
« Reply #6 on: February 07, 2012, 10:29:59 PM »
Tim, that's the first I've heard of it. I take it Mastercoat goes down, then paint with whatever for the desired finish? I've become pretty good at using POR15, but one complaint I have is that if I start with more than just a little bit of paint in a container, but the time I get to the other side of the axle, it's started to dry to the point where it doesn't go on quite as smooth.
After painting my front axle this past weekend, the driver's side is perfectly smooth and looks fantastic, but the short passenger side that was done after the differential case, looks more like alligator skin now that it's dry. It'll work fine for what I'm doing since I'll be adding a second coat and a shot of rattle can Rustoleum for the look I want, but it makes me wonder what would happen if I tried to do a large project like a frame over a period of time. I am using the smallest cans of POR15 I can get and pouring a very small amount into a second container, but if I had to do even less at a time and constantly go back to open the can, it'd take me weeks to do something the size of the frame to get a consistent coat, let alone 2.
Kurtis
« Reply #7 on: February 07, 2012, 11:04:32 PM »
Kurtis,
I didn't have that problem with the Mastercoat.  In fact, my first use was to brush on the entire underside of the tub.  It is moisture cured and actually took three days to dry so I could sand it and spray on the additional coats.  I must confess though,  I live in Colorado....moisture and humidity are not readily available here.  I was begining to wonder if it would ever dry.
If you read about it, you will think it's the answer to all your prayers.  If it's all true, it will ruin POR 15.
It has only been on my Willys for just over a year now.  So far, it's flawless.   I won't be able to get completely behind it for another 10 years or so.
Offline mrman5917
« Reply #8 on: February 07, 2012, 11:46:11 PM »
I'll certainly take a look. Living in the Mojave Desert of Southern California, humidity and moisture are probably even less available here :)
I'll give it a look though. I've got a bit of cleanup left, but I think I should get the frame finished before finishing the front axle. If I take the from axle off of the bench now, I'll have no place to put it but under a frame that still needs paint :)
Kurtis
« Reply #9 on: February 08, 2012, 04:12:37 PM »
Hey Kurtis,
I have used the POR on my first restoration wagon. The only problem I had was the drying of the primer. I sprayed both the primer and the chassis black. Looks great after almost 3 years now.  It does have a nice gloss but not too shiny.
I have decided to go with the mastercoat series on my CJ this time. Again I will spary it on and use the AG111 black over the primer. I am just about ready to do this as soon as it gets a little warmer in Ft Worth.
I made a paint booth outside with PVC and plastic sheets for my frame project. I also used a (cheap) fan (from Walmart) to suck out the fumes. I placed filters on the suction side of the fan. On the opposite side of the plastic booth I cut 2 square holes the size of a large air filter (20X16X1 filters) so that I could get fresh air (filtered). Be sure and wear a good resperator if you do this as well. Some of the spray/fumes are bad. Plus this will keep overspray off your other cars!
Offline mrman5917
« Reply #10 on: February 08, 2012, 04:21:28 PM »
Were the plastic sheets just the large painter's tarps you can get on the cheap?
What about getting a HVLP gun from a place like HarborFreight? I'm going to see if my father in law that used to run a body shop has a gun and some expertise to share with me, but if he doesn't have a gun available, are these any good for something like a frame job? Any idea how much Mastercoat and black I would need to sufficiently cover a frame? I imagine it wouldn't need much...
Kurtis
« Reply #11 on: February 08, 2012, 05:24:04 PM »
I used POR 15 on my frame and was very happy with it.  I brushed it on using cheap 2" brushes from Harbor Freight I bought by the box.  I bought two pints, but ended up using only one.  I brushed the POR 15 on in the morning, let it dry for two-three hours and then applied a topcoat of semigloss enamel paint.  I had enough left to do my drawbar, all five wheels, front and rear axle and various other parts I can't think of.  I even loaned some to a friend to paint the firewall and floor of a '65 Chevy truck..........and I still have around 1/2 pint left.  Two tricks I learned to keep it fresh and last longer:
1.  Get a cheap plastic pour lip that snaps to the can.  This keeps the paint from getting in the channel and preventing a tight seal.  As mentioned above, only pour out a small amount at a time and get a new brush when it starts drying out.
2.  Take a piece of Syran wrap and put it between the can and lid when you seal it up each time.  STORE IT IN THE FRIDGE! ( I have a full size fridge in my shop.....save the enviroment and keep it stocked with beer and paint, you'll use less electric to keep it cool  ;) )
For a HVLP paint gun, I like the Devilbiss brand.  Eastwood has a few kits for around $100-150 when they are on sale that has two guns in them, one for paint and one for primer.  One thing to watch though, the guns come with a HUGE tip (like 1.6 or 1.8mm) in them that is way too big for most anything you'll probably spray.  Even for filler primer, I swapped in a 1.2mm tip and had great success.  If you have never used a HVLP gun, it will take some getting used to.  When they say "high volume", they mean it  ;D  You don't have to have a good gun to paint and prime, but it sure makes a difference and you'll end up using less material.  One discloser:  I do my own primer work and paint on everything exept body panels.  My best friend owns a body shop and sprays all my sheet metal with his $700+ Devilbiss gun.  I asked him once if I could use it and you would think I asked him to kiss his wife.  Painters... :-?
« Reply #12 on: February 09, 2012, 02:11:21 PM »
Kurtis.
I am actually a fan of the Harbor Freight HVLPs.  I bought the 2 gun set and another one gun set.  With this combination, you get tips  1.2(mini gun), 1.4, 1.6, and 1.8mm.  Total investment with regulator and connectors was around $65.00.  I have nothing like a Devilbiss to compare to, but in my opinion, I was pleasantly surprised with the HF guns performance.
If you go this route I recommend that you dial the paint flow back a bit.  In the World Wide Web, it is often refered to as 'dry coat'.  (more air, less paint)  I am no pro.   Until I was more comfortable,  I found that dialing it back to a flow that mimics a rattle can, was helpful to me.    A pro can lay out a 'wet coat' (less air, more paint) and end with no runs or spatters.
I will say with regard to painting the frame, I was very particular.  I didn't want any runs or light areas. After all, my work was out there for all to see.  At least until I put the Willys back together. Now, very little frame can be seen.   With that said, focus on great prep and excellent coverage with the goal of never having to deal with a rusty frame again.
« Reply #13 on: February 09, 2012, 04:02:24 PM »
I used the large plastic sheets just like the painters drop cloths but you do not have to get more than 2 mil thickness. The cost goes up!
I also have the HF HVLP guns and once you get the hang of spraying it will look really nice. Just like Tim said dial it back a bit to get light coats on your first attemt. I also practiced with some solvent (thinner) on a piece of corrugated board to see what the spary pattern looked like - there is an ideal setting and spray pattern - I then was confident enough to spray more paint than air and it looked great. On the fram of my first restoration Willys wagon I only used less than a quart. I also sprayed the front and rear axle and a number of small parts.
You'll do just fine and remember 80% preperation - 10% actual work - 10% clean up.
George
Offline mrman5917
« Reply #14 on: February 09, 2012, 04:38:04 PM »
Thanks for the reply guys.
Mark - I started using the syran wrap after the first can didn't get quick a good seal on it. Made a huge difference. I'm using the little mini 4 oz. cans, so I doubt there is a pour spout that will fit on those little ones.
Tim - Would you recommend the 2-gun kit specifically for the 1.2 mm nozzle on it? Aside from the gun, anything else I would need to get to make it work properly?
George - Sounds like a quart of primer and a quart of top coat are what I'll need. That helps me figure out how cost effective it will be to build a paint booth and stock it up :)
How much room around the frame should I have? I don't know what sort of distance I would need to have from the "wall" and the frame with regards to holding the gun and having myself in there.
Kurtis
