Author Topic: Wiring harness holes  (Read 2251 times)
« on: February 01, 2012, 09:42:29 AM »
So I am finally finishing up the fab work on my repro tub.  I am really trying to get all my holes drilled before I start paint prep......which brings me to my question:
Does anyone have a diagram or photos or know where the wiring harness straps are screwed into the body?  I don't know if there was a specific location or if the factory just used sheet metal screws and screwed them in wherever they hit.
Any help or am I just being a little too exact?  ::)
Re: Wiring harness holes
« Reply #1 on: February 03, 2012, 02:55:03 AM »
Sorry for the late response. �I'm not sure exactly which part or parts of the wiring harness you are talking about. �I was hoping someone else would have a better answer. �Here's my best response. �The part of the harness down along the left frame member back to the tail lights was held on with some U shaped clips that encompassed the harness and then was pushed over a leg of the U shaped frame and retained in place with the teeth made into the clip. �I just cleaned up and reused the original ones I had removed. �Other portions of the harness attached to the firewall and left front fender with Adel clamps (aviation term), clamps that wrap around the harness leaving two ears, one stacked on the other with a screw hole in them. �I didn't drill those holes before paint because I wasn't exactly sure where the clamps were going to be positioned till I ran the harness, even though I had my old tub and fenders along side my new tub and fenders. �Maybe after this response someone else will chime in with another approach and better pics. I have to acknowledge my deviation from original here in the use of white MIL-SPEC aviation wire when I made up my new harness.
« Last Edit: February 03, 2012, 03:00:27 AM by calvinhunt »
« Reply #2 on: February 03, 2012, 11:06:41 AM »
Hey Mac.
I'm with Calvin on the slow response. �I know there is a pretty good �set of instructions out there. �I can't remember where I saw them. �I don't think portions of my harness are mounted in an original position...although I tried. �
The one clip and hole I am pretty certain of is the one just below where the main harness leaves the firewall and heads down toward the rear harness. �You can see it in this photo. � �Otherwise, I used holes that were already drilled. �You can see in my photo, a horn voltage regulator mounted to the driver side fender. �That is probably not needed in you Willys.
I got my Harness from Walcks. �Based on how it was put together, pretty much determined where my harness mounts were going to end up.
« Reply #3 on: February 03, 2012, 11:41:44 AM »
Thanks guys!  This was exactly what I was looking for.  I transfered my holes on the old fender over to my new one, but I'll probably wait until I get the body painted before I drill anything in the firewall.  I was concerned there were some clamps attatched to the tub underneath, but it looks like the harness runs along the frame.  Is that correct?
Since this is a repro tub, I think I'll wait until I have the body completely assembled after paint.  I want to make sure my wires are tied back out of the way.  There are so many little differences in the Omix tub and the factory one, you just don't ever know when something is going to creep up!
« Reply #4 on: February 03, 2012, 12:41:28 PM »
The rear harness does run to the back in the frame rail. Attached is a photo of the clips used to hold it in the frame. �I don't know the exact position of these, nor do I know how many there would be for an original set up. �I only had 2, so I positioned them where I thought they would do the most good. �There is a small barb that is pressed onto the frame.
Photo is Courtesy of Willys Jeep Parts (Jungle Jims)
