Hey Comanche,
I got my DANA 18 seal kit from Walcks. �It had all the seals and gaskets, was reasonably priced and they fit as they should.
I used Permatex "2" on the splines, on the output yoke (front) and the companion flange (rear).
I put the new felt seal where I found my old one. It goes on the output companion flange. This is the part that has the splines and ultimately is attached to the propeller shaft. � On the front output yoke, there is a protective cup that has a internal ridge that the felt seal sits in. �I think the felt seal acts more like a dust seal than an oil seal.
Here is a link that was very helpful to me.
http://www.novak-adapt.com/knowledge/dana_18_rebuild_guide.htmMy hand brake assembly was full of crud when I took it apart. �So far, it's about the only thing I sealed that hasn't sprung a leak.
Tim � �
