Author Topic: Re: 3a seat frame  (Read 3097 times)
Re: 3a seat frame
« on: January 31, 2012, 07:49:57 PM »
Hey Mac.
Your photo puzzled me. �I went out to look at mine, then got more puzzled. �I scrolled back and looked at your #10 photo on Photobucket and it seemed as if the seat frame or the tank is mis-positioned or too large. �The tank looks just like mine. �
Is the seat frame a new repro? �I must warn you, I have 2A seats in a 3A Willys, but they bolted right up in the same holes. I haven't seen a 3A seat up close, and they are different than mine, but your seat frame seems too wide and maybe too long. �At the front, top, just before the curve down, I measured 20 1/2" from outside of tube to outside of tube.  Is the rear wheel house a 2A?  They are larger and that may push your seat too far forward.�
Here are a couple photos of mine. �
I know I'm not helping. �Perhaps a 3A seat owner will chime in.
« Last Edit: January 31, 2012, 07:52:45 PM by athawk11 »
Offline Macgraham
Re: 3a seat frame
« Reply #1 on: January 31, 2012, 08:38:31 PM »
I've been puzzled for a long time. I sent back the original frame I bought and they sent me another one. Same problem. The inner fenders are 32 inches which I think indicates 3A. I know something is not right here which is in keeping with the rest of the Jeep. It looks like a new floor pan was welded in at one time. What next!!
« Last Edit: January 31, 2012, 08:41:54 PM by Macgraham »
Re: 3a seat frame
« Reply #2 on: January 31, 2012, 09:33:50 PM »
The right side leg should sit outside of the gas tank. That hole under the leg doesn't belong there.
Re: 3a seat frame
« Reply #3 on: February 01, 2012, 06:55:58 AM »
Is it just me or is your toolbox floating on the center side and not welded down?
Offline Macgraham
Re: 3a seat frame
« Reply #4 on: February 01, 2012, 07:36:34 AM »
The toolbox is not welded down in that pic. there was another gas tank under the pass. seat and I took it out and got a toolbox. This made it possible to have the proper passenger seat as the hinges bolt to the toolbox.
Offline Macgraham
Re: 3a seat frame
« Reply #5 on: February 01, 2012, 08:08:18 AM »
<a href="http://s1067.photobucket.com/albums/u424/macgraham/JEEP%20REBUILD/?action=view&amp;current=PA270017.jpg" target="_blank"><img src="http://i1067.photobucket.com/albums/u424/macgraham/JEEP%20REBUILD/PA270017.jpg" border="0"
alt="Photobucket"></a>
Here is a pic of the gastank door on the pass side. I have removed it and and welded it up.
Re: 3a seat frame
« Reply #6 on: February 01, 2012, 12:36:14 PM »
Tip:
To have pics show up here, surround them with url]enter link here[/url �(put the brackets also on the ends. �i cant get it show here right if i try to give an example)
Photobucket makes it even easier. �There is a box called 'links', click on 'IMG Code'. �It will copy the wording for you then you can paste it in your post.
« Last Edit: February 01, 2012, 12:39:14 PM by bretto »
Offline Matto
Re: 3a seat frame
« Reply #7 on: February 01, 2012, 04:28:08 PM »
Mac, Is that a fuel petcock or spare tank manifold on the floor between the gas pedal and tank in pic#2?
Offline Macgraham
Re: 3a seat frame
« Reply #8 on: February 01, 2012, 05:34:27 PM »
It was afuel valve to switch tanks. Both tanks were full of rust so I got a new tank and eliminated the valve.
