Author Topic: Master Cylinder Heat Shield  (Read 5106 times)
« on: January 20, 2012, 04:25:22 PM »
What do you guys know about the MC Heat shield?
Is it standard equipment or an option?
Is it neccesary?
What happens if you don't have one?
Triple X didn't have one so i didn't bother with it, do I need one?
Re: Master Cylinder Heat Shield
« Reply #1 on: January 20, 2012, 04:39:49 PM »
When I rebuilt my MC I had a lot of trouble getting it back in with the shield. I finally gave up and left it off. I have drove it summer and winter and have not had an issue.
« Reply #2 on: January 20, 2012, 08:03:34 PM »
It was original factory equipment and I would recommend one be installed. It's generally assumed it was designed to help protect the Master Cylinder from heating up but, if you look at how it fits you'll notice it's actually protecting the forward fitting, lines, switch, and switch wires. It's cheap insurance.
Imagine you're booking down the highway for a while, you arrive at your destination, you park the jeep and turn off the engine. That exhaust pipe is very hot and, since the vehicle is no longer moving, there is nothing to dissipate that heat so it rises upward and overheats the lines and switch. At the very least the brake fluid in the line will overheat and expand back into the MC possibly intoducing bubbles into the fluid. Heat can damage the switch as well. Not worth the risk in my book.
« Reply #3 on: January 21, 2012, 08:43:10 AM »
Rock,
I knew I could count on you for a picture.  Thanks, I'm going to pick one up, I was at Johns this week (Midwest Military) and saw he has a bunch.
Todd
« Reply #4 on: January 24, 2012, 11:18:23 AM »
I have had the heat shield in the back of my mind along with a bunch of other things I will need to do on my rebuild.  But regarding the heat sheild, it is a simple design.  I know the original was made of asbestos so I can't and wouldn't want to make one from that.  Do you guys think one made out of some aluminum plate would suffice?  Another option maybe would be a carbon fiber sheet.
« Reply #5 on: January 24, 2012, 11:28:30 AM »
If you don't have an insulation layer on top of the shield then the metal will just radiate the heat upward defeating the purpose.
« Reply #6 on: January 24, 2012, 12:48:35 PM »
I looked at the ones at Midwest Military, they are a metal bracket with a fiber board insulation layer, John does a good job with his repro stuff.  I think this would be a good one just based on his particular nature for his product.
« Reply #7 on: January 24, 2012, 01:44:47 PM »
I'm all about building my own stuff if I can.  Anyone know what that fiber board stuff is officially called?  Although John's price at MWM of $40 isnt bad.
« Reply #8 on: January 24, 2012, 06:43:05 PM »
It looks like the same kind of stuff that old PC boards were made of, that brown fiber board stuff with lots of epoxy impregnated in it.
Offline johnnybravo
« Reply #9 on: January 27, 2012, 09:29:30 PM »
No insulating material.  You can drill three or four holes and screw 1/4" metal screws to act as diffusers or cooling fins/post.  I have done this on heat shields on underground mining equipment.  Works quite well.
« Reply #10 on: January 27, 2012, 09:51:53 PM »
There is a significant difference between a diffuser and a shield. A diffuser is to disappate heat while a shield is, well, to shield against heat. Two entirely different functions. In order to protect the switch and lines you need insulation.
Offline johnnybravo
« Reply #11 on: January 28, 2012, 11:22:10 PM »
ROCKETEER, YOU ARE CORRECT, BUT WHEN YOU DON'T HAVE INSULATION YOU SHOULD DO SOMETHING TO REDUCE/DISSIPATE THE HEAT BEFORE IT DESTROYS CRITICAL ITEMS.  THIS IS ONLY A BAND-AID AND I SHOULD HAVE SAID SO.  INSULATION IS BEST BUT IF YOU DO NOT HAVE, WHAT IS THE NEXT BEST THING?  IN OUR HOBBY JEEP WORLD WE HAVE TIME TO GET THE CORRECT RESOURCES AND DO THE JOB PROPERLY.
