Author Topic: Toe In Adjustment  (Read 7349 times)
Toe In Adjustment
« on: January 21, 2012, 10:35:12 PM »
I searched the old site for threads about toe in adjustments.  I'm sure it's been covered before, but if the keyword search is less than 4 characters like Toe In, it just won't work.
I read the article at Vernco.com.  Pretty good information about checking and adjusting toe in.
I did not mess with the tie rods during the re-furb.  (I tended to focus on things that were difficult to do when the Willys is assembled, and save things like toe in, u-joints, brake work, once I had it cleaned up and back together.)
My toe in appears to be about  5/8" on driver side  and 3/8" on passenger side.  Way to much!!!!   Why would PO set the toe in this much?  Just bad work?  Or was he trying to compensate for something else that was causing him trouble?
I will adjust it to proper specs in the next few days,  I just want to understand.
This Jeep never Death Wobbles.  Stearing is a little loose (2" of free travel) in the center while driving straight.  I did see some information on the old site on adjusting this issue.
Re: Toe In Adjustment
« Reply #1 on: January 21, 2012, 11:22:19 PM »
Hi Tim,  See if this is the thread you were thinking of:
http://cj-3a.com/forum/YaBB.pl?num=1319055949;start=all
Also, in the Universal manual the alignment procedure (toe in) is described in the "steering" section I believe.  I remember having a hard time finding it because I was looking under the "frame" and "suspension" sections.  I'm guessing that you checked to make sure you had a square frame when you had the body off, I think I remember you said that.  Good luck!
« Reply #2 on: January 21, 2012, 11:23:25 PM »
Although the illustration in the manuals shows separate measurements for the passenger and drivers side the actual measurements are taken as follows:
Scribe a line with a pencil or Magic Marker in the center of the tread of each front tire half way up the front and half way up the back.
Using a measuring tape, measure from line to line, first across the front and then across the back.
The difference between the two is the toe-in, with the front being less than the back.
A CJ toe-in should be 3/64" to 3/32".
« Reply #3 on: January 21, 2012, 11:26:29 PM »
The toe-in is not different on each side, it is the same and measured with the steering box centered and the wheels straight ahead. There is a recent thread on toe-in and it shouldn't be hard to find.
You have to start with turning the wheel all the way to one side and then count the turns to the other side, divide that in half and then turn the wheel that much. Now the steering box is centered and if one spoke is not facing straight up you may want to remove the steering wheel and align it.
Then jack up the front end and spin the front wheels to see if the rims are bent. If they are not bent then measure the distance from the front of the rims at axle level and the rear of the rims as high as you can on the rims. The difference is toe-in or toe-out. If the distance it greater in front you have toe-out. If the distance is greater at the rear you have toe-in.
EDIT: Rocketeer is giving a better way of measuring the toe-in but be very careful to get a line that doesn't wiggle.
« Last Edit: January 21, 2012, 11:29:56 PM by Carlsjeep »
« Reply #4 on: January 22, 2012, 10:04:42 AM »
Just a note here, make sure the front wheels are on the ground with the full weight of the vehicle on them, otherwise your measurments will not be correct.
« Reply #5 on: January 23, 2012, 11:17:02 PM »
I did work on my toe in adjustments.  I used both techniques that were suggested in an attempt double checked the measurements.  My toe in was set at a combined total of 7/8".  I was a bit shocked, frankly.  I reset the toe in to the specs Rocketeer mentioned.    The toughest part was getting my steering box centered and set dead straight.
I took it for a spin and it performed fine.
Carl, as I try to understand how this works, I centered the steering box and it seemed when I measured with the string technique, the driver side was toed in more than the passenger side.  There are two tie rods that can be adjusted. Is it possible to over adjust one tie rod causing the toe in to be uneven?  Again, you know far more about this stuff than I do.  Just working out the mechanics in my mind.
« Reply #6 on: January 24, 2012, 08:40:28 AM »
To get the scribed line in my tires, I place a jackstand in front of the tire as close as I can get it, and use a piece of chalk to mark a line on the tread on an area of the tire that is as solid as possible. �On �NDT tires this would be the rib that runs all the way around the center of the tire.. On other tires, just pick a place as smooth as possible. �Then , scribe a line in your chalk line with an awl. I find it easiest if someone else rotates the jacked up tire as I hold the awl on top of the stand, and slowly get it closer to the tire until it leaves a mark. Take the jack out when you measure, as someone already noted it needs to be on the grond in normal driving position. Rolling it back and forth a foot or so will allow it to settle to the way it would be on the road. (Not as important on a solid axle in good shape, but very important on something like a 2WD Jeepster...
THen it is a simple tape measure procedure to measure between the marks on each tire, Ideally you want to measure halfway up the tire but suspension parts and the frame get in the way of your measuring tape. You can make a jig that lays on the floor with pointers that come up to the center of the tire, but most times a tape measure works just fine. �The difference between your measurement on the front of the tire and at the back of the tires is your total toe in. THe measurement should be smaller at the front. If it is larger there, you have toe out. (not good for handling...)If you do use this method go for the smaller end of the specification for toe in, as measuring �this way gives you a smaller number than actual toe unless yu can measure right at the center vertically.
I have set toe this way on all my vehicles including my escort truck that gets 100,000 miles a year, and it works just fine.
Offline ventport
« Reply #7 on: January 24, 2012, 09:38:06 AM »
I have found the easiest way to scribe the line on the tires is to drive a large spike through a piece of 2X6 about 18 inches long.  Jack up the front end and hold the 2X6 flat on the floor with the tip of the spike against the front of the tire, then spin the tire backwards with the spike drawing a line in the dust down the center of the tire.  If the tire is spun forward the spike will dig into the tire.
« Reply #8 on: January 24, 2012, 10:00:52 AM »
Yes, when you center the steering box gears it is possible for one wheel to be turned more in or out than the other. The reason is the toe-in was set with the steering box out of center and because the wheel to the inside of a turn is in a smaller radius than the outside tire one may end up farther off than the other.
There is one thing I haven't mentioned, when you center the steering box you need to put a 48" ruler or a long piece of flat iron against the side of the tire and see if each front tire is straight ahead. The ruler or flat bar should show the front tire is parallel to the rear tire. Another way is to stretch a string from the front side of the front tire to the rear side of the rear tire and the string should touch each tire at two points and that requires the rims not be bent. � that is the only way you can be sure the front tires are lined up to go straight ahead. Setting the toe-in can get a little tricky if everything is way out.
To get everything set right you have to center the steering box first, then the steering wheel, then be sure both front tires are straight ahead and then you can set the toe-in. To set the toe-in you move each tie rod half the distance you need to get the total distance.
front end alignment machines have features to do all this with ease. Doing it at home is not so easy to do it right. I still have my uncles rotary tables and alignment tools. I haven't used them much lately but yesterday I used them to set the turn angle so the wheels don't turn to far. I found they were both turning about 30 deg and I set them for about 24 deg which is close to spec. for the minimum turn angle.
Most home mechanics just set the tires with the toe-in in the specs and don't worry about if the steering box is centered or the steering wheel is centered.
A good way to know if after you centered the steering box, the steering wheel and the tires and then set the toe-in is during the road test you have to hold the wheel to one side to go in a straight line on a flat surface such as a parking lot. You may not have had everything centered before you set the toe-in. Of course all this depends on the front and rear axles being correctly aligned to the frame and that the frame is not bent or out of square.
Are you beginning to see how complicated it can get?
The truth of the matter is how important is it to you to have it correctly set? That is the question you have to ask yourself.
« Reply #9 on: January 24, 2012, 12:48:21 PM »
Ventport,
Cool idea.  I was lucky enought to have new NDCC tires.  The mold line down the center is still very visable.
Carl, thank you for the detailed explanation.  I appreciate it.  As you said, the most difficult and time consuming issue I had was making sure the steering box, thus the wheels, were aligned straight forward.  Constant measuring between the back and front of the tires, a string from rear tires to fronts, and an aluminum straight edge... rolling the Jeep forward, measuring again, then doing it all over numorous times to make sure all was dead straight.
My toe in measurement kept coming out the same.  7/8", with more toe in on the driver side...  I adjusted both wheels to '0' toe in, then set identical toe in on each side.
I can only speculate, but I think the PO wasn't as causious and careful the last time toe in was done.
Thanks again.
