Finally got around to bleeding brakes. discovered huge amounts of air in the rear lines, along with ugly looking fluid. So I started from scratch, and adjusted all four brakes, then bled systematically from right rear to front left. Entire system has new fluid, and no air. Furthermore, pads are all close to drum now, unlike previously.
So why do I now have a soft pedal? Travel is 2/3s way to floor on first application. Then with two pumps, it is up high and very firm. In fact it is firm on the first application, just has lots of travel. I'm mystified, it doesn't seem logical.
Now that shoes are adusted, presumably the brake cylinders have a bit further to travel than before? But that's the only thing I can imagine would cause pedal to travel more than before, especially since there was so much air in line previously.
Thoughts? Thanks!
