Author Topic: Chassis Holes...Am I Missing Something?  (Read 3158 times)
« on: December 18, 2011, 09:44:24 PM »
Re-assembly is almost complete. �Please pay no attention to the dust build up. �
I have two threaded holes in the passenger side of my 3A chassis. �Don't remember there being anything mounted here before I took the Willys apart.
So, am I missing something? �What belongs here?
Re: Chassis Holes...Am I Missing Something?
« Reply #1 on: December 20, 2011, 06:50:51 AM »
The upper hole with the arrow and the hole to its right (with a bolt in it) are for the early style fender. The splash apron was bolted to the frame at those points. Do you still have the original right fender?
« Reply #2 on: December 20, 2011, 09:08:39 PM »
Lower left hole possibly for optional propeller shaft guard?
« Reply #3 on: December 20, 2011, 11:08:49 PM »
Hi Bob.
I was begining to think that I stumped the group as it took a bit to hear back. �My driver side fender does have the bolted on splash apron. �The passenger fender does not. �And I think both fenders are original to this Willys. �They were clearly both painted original Pasture Green. �As was all the sheet metal on this one. �Is it possible I ended up with one older and one newer style fenders during production?
I ask this only because this Willys has other contradictions. �I have read your "Dating the 3A" page. �Another od example is my radiator mount. �It is a bottom mount with the rod from the radiator to the cowl. That's fine, but the Jeep is a 1949, �#36662. �According to the listed bulletins, �it should be a grille mount. �Or is this one of those Jeeps that fell into the... �
 "During the production of the Model CJ-3A with the side mount radiator, it was necessary to use a small quantity of bottom mounted radiators".
I don't know, this is all very confusing at times. �
After reading your post on the propeller guard, like always, you are right. �I did find some information on the 3B page regarding the probable use for the lower threaded hole.
I included the link below. Pretty interesting information.
http://api.viglink.com/api/click?format=go&drKey=1081&loc=http%3A%2F%2Fz4.invisionfree.com%2FCJ3B_Bulletin_Board%2Findex.php%3Fshowtopic%3D3400&v=1&libid=1324437401266&out=http%3A%2F%2Fwww.thecj2apage.com%2Fforums%2Fgrass-shields_topic11075.html&ref=http%3A%2F%2Fwww.bing.com%2Fsearch%3Fq%3Dwillys%2Bjeep%2Bpropeller%2Bshaft%2Bguard%26form%3DASUMHP%26qs%3Dn%26sk%3D&title=CJ3B%20Bulletin%20Board%20-%3E%20PROPELLER%20SHAFT%20GUARD&txt=http%3A%2F%2Fwww.thecj2apage.com%2Fforums%2Fgrass-shields_topic11075.html&jsonp=vglnk_jsonp_13244401783126
As always, I am thankful for your knowledge, and I am a huge fan.
 ï¿½
« Reply #4 on: December 21, 2011, 06:54:25 AM »
During the 1949 model year 3 different right fender types appear on CJ-3As. Your fender looks so nice �:) I just assumed it had been replaced �:-[ �
Your Jeep does fall into that period when a batch of bottom mounted radiators were used, so that is normal for your 3A also.
« Reply #5 on: December 21, 2011, 12:27:27 PM »
Thanks Bob. �I appreciate your comments on the fender. �But if you got up close and personal, you would see many imperfections. �I wanted to keep as much original sheet metal as I could, but both fenders required all new support channels, patches behind the support channels, a bit of work around the battery tray, and new sheet metal for the entire top of the fenders. �This fender also required a few hours to pound out the area that attaches to the grille. �I should have patched a few more drilled mounting holes that aren't needed anymore, but lost track of good holes and bad holes.
They were pretty rough. �In hind sight, replacing them would have probably been a better use of my time. �I know what your thinking..."he put all that effort into this, but didn't restore it back to original...crazy!"
« Reply #6 on: December 21, 2011, 02:41:42 PM »
Hawk,
I used the same strategy, use as much of the original as possible and fix what you can.  It looks to me like you have a real nice looking resto, that is a pretty jeep.  Nice work.
« Reply #7 on: December 21, 2011, 08:03:16 PM »
Tim,
Your CJ-3A looks great! The most important thing is to have fun.  :)
« Reply #8 on: December 23, 2011, 01:19:24 PM »
It's been fun to follow your progress.  You have a very great looking Jeep.
« Reply #9 on: December 23, 2011, 01:46:22 PM »
Thanks to all for the help and kind words.
I have another problem I'm hoping there is an easy answer for, but I'll start another topic.
Merry Christmas to all...and a Happy New Year.
