Author Topic: Timing??  (Read 2148 times)
Offline philshevlin
Timing??
« on: November 05, 2011, 07:38:51 PM »
Do you time a 3a the same as a 2a?  My timing window is partially blocked.
Re: Timing??
« Reply #1 on: November 05, 2011, 08:09:07 PM »
Well I've got timing, a ticka ticka ticka good timing and that brought me to you. Well, it's an old song and I just couldn't resist.  ;D
You got your answer in the CJ2A site but I'll add mine. Remove the starter, use a die grinder to enlarge the hole and make a cover plate.
Re: Timing??
« Reply #2 on: November 05, 2011, 09:41:07 PM »
Looks like your block is a newer 3A block, the inspection hole is covered because its the same block as used on the M38.  That had a different configuration.  I've got the same problem so I went to John at Midwest Military and bought a timing indicator that bolts onto the front cover. Looks just like the  arrows on a 60's chevy or ford.  Saves me a lot of headache and its right on.
Todd
Offline philshevlin
Re: Timing??
« Reply #3 on: November 06, 2011, 07:25:02 AM »
Thanks!
