Author Topic: Bendix Axles  (Read 2096 times)
Bendix Axles
« on: September 06, 2011, 11:25:07 AM »
Started to tear down the front axle this weekend. Not sure what I would find but after removing all the grease from the knuckles but found that I had Bendix style axles. Now after chasing the 5 balls that fell out on each side I cleaned them up as well as the axles. The balls were in really great shape with no indication of wear but the axle portion had indications (wear marks). Not sure what is acceptable in this case. Do I bolt it back together and check end play or go for 2 new (or used) spicer axles.
Suggestions?
George
Offline RussellL
Re: Bendix Axles
« Reply #1 on: September 06, 2011, 07:05:04 PM »
How much do you use your 4wd?  Was there any indication of problems before you took it apart?  The way those knuckles are built, I'd think it would have to be a lot of wear before they were in danger of falling apart or breaking.  If you only use the 4wd occasionally and don't have to trust your life to it, I'd lube them up and put them back together.  Thats what I'd do anyway.  I don't  even think you can buy that same style axle new.
Re: Bendix Axles
« Reply #2 on: September 07, 2011, 09:19:05 AM »
Hey RussellL,
You have a good point. The CJ was not running when I purchased it so I am not sure about the 4WD. I think what I will do is do a dry fit to see how much slop I have in the axles. I may have to bite the bullet and get new spicer axles if there is too much play.
George
Offline calvinhunt
Re: Bendix Axles
« Reply #3 on: September 07, 2011, 10:58:30 AM »
I found new left and right Spicer axles during the rebuild of my Jeep just over three years ago on eBay at good prices.  They came from different sources and it took a little patience to keep checking, but I did well.  I just checked and there are a few axles listed now to give you an idea what's often available.  There are some new Bendix axles and other stuff but nothing really great right now.  Keep checking.
Calvin
Santa Clara, Utah
