Author Topic: Softer Ride springs  (Read 5496 times)
Softer Ride springs
« on: September 03, 2011, 06:27:12 PM »
Gents
I've got a set of aftermarket springs on the front of the jeep, backs are original, the ride seems awful rough, as the front seems to hammer on every bump in the road.  I rode in an original, unmolested 3B the other day and it was a considerably softer ride.  I've heard of putting Wrangler springs on the front as an alternative to the aftermarket version.  Does anyone have any experience with this? Does it really help?  Are they difficult to put in? Are there any other options to softening the ride a bit? Sorry I'm asking a lot of questions, but I don't want to jump into this unarmed.
Thanks for the help
Todd
Re: Softer Ride springs
« Reply #1 on: September 04, 2011, 09:50:06 AM »
How many leaves are in the after-market springs?
« Reply #2 on: September 04, 2011, 11:35:46 AM »
Have you verified that your shocks are in good shape?
« Reply #3 on: September 04, 2011, 01:06:04 PM »
The aftermarket springs have 7 leaves, and they seem like they are a bit thicker than the OEM springs I took off. And yes the shocks are actually new, they are the Gabriel OE replacement, standard shocks.
« Reply #4 on: September 04, 2011, 03:35:50 PM »
There is nothing soft about the ride of my CJ3A, it's kind of like an old farm wagon. It's kind of supposed to be that way.
« Reply #5 on: September 04, 2011, 04:45:51 PM »
I know what you mean about wanting a smoother ride.  I have an M38 with a heavy duty set up - 11 leaves on the front and 10 on the rear and, as Carl mentioned - it rides like a jeep.  I don't know much about after market mods, but if your shocks are good and there isn't anything obvious, I'm not sure there is much to be done.  Do your springs still have decent arch to them?
As an aside,  I sure wish I had the original spring seats.  The foam ones that Beechwood makes up are really firm and quite uncomfortable.  Hard to drive for more than an hour without a rest.
« Reply #6 on: September 04, 2011, 05:51:24 PM »
I know what you mean about the seats, I've got foam ones that I had made for me, I picked out two different densities of foam at an apolstry shop, 2" of heavy foam on the bottom 3 inches of soft on the top.  Pretty nice for the first hour, then its boney butt time.
« Reply #7 on: September 04, 2011, 07:26:41 PM »
Did you install the after-market springs and if so, where did you get them?
That 3B may ride softer for a couple of reasons; the springs may be shot, the shocks may be shot, and/or the tires may be under-inflated. These flat fenders are technically 1/4 ton trucks. They are designed for work, not pleasure or comfort. Tis the nature of the beast. By the way, I have original spring seats in mine. Somewhat comfy driving but I do have to take a leak when I get home. It does massage the kidneys. �;)
« Reply #8 on: September 05, 2011, 09:04:20 AM »
I did install the aftermarket springs, It was a while ago, but I think I got them from 4 Wheel Parts.  They fit up very well, no issues there, and I've been happy with them.  I bought and installed them soon after I got the jeep, 4 years ago.  Not having any prior experience with jeeps I'm not really aware of how they are supposed to ride and drive so I'm learning on the fly.
You know how this process goes Rocket, you figure it out, install it, fix something else and after a while you come back to the first stuff you fixed and figure out if you did it right or not.  Most times you learned a little more along the way and then you decide if it needs re-fixing or just an adjustment or two... :-?
Thanks guys, I think I'll leave the front springs alone and fix some other stuff.
« Reply #9 on: September 05, 2011, 09:28:00 AM »
If you got them from a place like 4 Wheel Parts they may, in fact, be "performance" springs. Most after-market houses deal in "performance" type springs rather than replacement type springs. That may be why the leaves are fewer (std is 8 leaves front, 9 leaves rear) and heavier. That could account for some of the harsh ride.
« Reply #10 on: September 05, 2011, 06:20:46 PM »
Good thought, I'm going to be at one tommorow, I'll ask them, thanks
