Author Topic: Wiring from Ammeter to Starter and Battery  (Read 5849 times)
Offline Ranger41
« on: September 01, 2011, 10:34:27 PM »
I'm in the process of rewiring my 1950 3A (the old bubba wiring went up in a wisp of smoke).  At some point in the past someone installed a starter relay on the firewall and had a push button start. I'm trying to take it back to original and putting in all new harnesses and a 3 post keyed switch.  My question is, the wiring diagrams show wire running from the Ammeter post to the starter post and the pos. battery cable running right the starter post, with no relay or switch in between.  Does that sound right?  I know the 3A's a had a few different starting configurations: floor plunger, keyed, etc. Any photos of 3A starter wiring would be much appreciated,  Thanks - JB
Re: Wiring from Ammeter to Starter and Battery
« Reply #1 on: September 02, 2011, 08:35:26 AM »
Are you going to buy a wiring loom or make your own? If you don't have the Willys Mechanics shop manual I suggest you buy one. It has wiring diagrams and lots of info to repair the Jeep. It's easy to wire the Jeep yourself. I can scan the diagram but I am sure Sean has one to post. There are threads with wiring diagrams in them on the site.
The post on the starter is an easy place to put the ammeter wire.
Offline Ranger41
« Reply #2 on: September 02, 2011, 09:19:10 PM »
Thanks for the response.  I have the diagram and the manual, and have new wiring harnesses 80% installed.  The diagram for the 3A http://www.cj3a.info/tech/Elecpart.html   shows the ignition switch, but no additional relay or solenoid on the starter circuit.  It puzzles me because every other model from 2A's to 3B's and early CJ5's have a solenoid or starter relay.
« Reply #3 on: September 02, 2011, 10:52:30 PM »
My Jeep is a '51 CJ3A and has the foot starter. Not many people know how to start a Jeep with the foot starter. If I leave the key in it in town I doubt any young punk could start it before I got there.
I didn't buy a loom, just bought some wire and rewired it myself. Jeeps wiring is very simple as long as you have a diagram for the switches.
« Last Edit: September 02, 2011, 10:56:01 PM by Carlsjeep »
« Reply #4 on: September 03, 2011, 09:08:11 AM »
If you use a key start, or a push button start you need the solenoid.  This is because the starter circuit draws way more current than the key switch or the push button can handle.  So you have to have a secondary circuit, the first turns on the ignition with a key, provides power to the coil and to the solenoid, the secondary circuit flows through the solenoid to provid power to the starter, this way you don't burn up the small switches that control the ignition.
With the foot starter the switch that controls the starting circuit is manually operated by your foot, so you don't need the secondary circuit.  Lots simpler to wire, ancdCarl is right, not many people remember or know about the starter button, and on the 3A you can't really see it very well.
« Reply #5 on: September 03, 2011, 05:29:40 PM »
As Carl mentioned, the CJ3A has a foot operated starter. Does your starter look like this?
http://cj-3a.com/installing_the_correct_pushrod_s.htm
Offline RussellL
« Reply #6 on: September 03, 2011, 06:20:29 PM »
Like the other guys said, all starters need a big switch to connect them to the battery.  Some have this switch mounted on the starter and it can be operated either by your foot or by a solenoid relay triggered by the key.  Others have the relay switch mounted on the fender and only one big wire going to the starter.  The starters that have the relay mounted on the starter usually use this same relay action to engage the drive gear with a big magnet or with power from your foot.  The starters that have a separate relay use centrifugal action to engage the drive gear.  If you have a relay on the fender, it will work the same as your diagram but the wire from the key to the starter goes to that relay on the fender instead.
