Author Topic: windshield frame  (Read 3991 times)
Offline muddog444
windshield frame
« on: August 13, 2011, 02:06:57 AM »
i am putting a new windshield frame on the jeep and for some reason it is off centered to the driverside by about  5/8 inch. does anyone know of an adjustment or the beast way to tweek the fram so it sits properly
Re: windshield frame
« Reply #1 on: August 13, 2011, 09:06:29 PM »
When you say "new windshield" does that mean a used one that is new to you and your Jeep, or a "new" reproduction (Omix-Ada) windshield?
Offline muddog444
« Reply #2 on: August 13, 2011, 09:10:16 PM »
its a new reproduction on a new reprodution tub.
Offline Chasm
  • Bald Heads for Flat Heads
« Reply #3 on: August 14, 2011, 08:05:18 AM »
Most of the big parts from the Philippines are at least 1/2" or more off. The quality control isn't that great. I would suggest returning it to the supplier and looking for a good used one. If you try to straighten the new one and it doesn't work, you're gonna be stuck with it.
Offline Bill04SD
« Reply #4 on: August 14, 2011, 02:24:43 PM »
I think your options are to either send it back or bend the arms to get it centered.
I'd bolt it on and lay it down on the hood blocks.  Either push or pull on it the way it needs to go, stand it up and check alignment.  Repeat as needed.  Having a helper may be useful.
« Reply #5 on: August 15, 2011, 10:04:48 AM »
On my reproduction tub and windshield, I have had to tweak on them a little bit to get them to line up.  Like Chasm said, the QC from the Philipines isn't exactly up to ISO specs......
Offline Chasm
« Reply #6 on: August 15, 2011, 02:49:30 PM »
On my reproduction tub and windshield, I have had to tweak on them a little bit to get them to line up. �Like Chasm said, the QC from the Philipines isn't exactly up to ISO specs......
That's funny Mac! You used ISO and the Philippines in the same sentence!  ::)
« Reply #7 on: August 16, 2011, 12:18:30 PM »
Don't get me wrong, I am thankful there is at least SOME place we can get reproduction parts for these old Jeeps.  However, I was a Quality Engineer in the auto industry and I know how simple some of these changes would be to fix the problems with some of these parts!  It both puzzles and frustrates me when I come across these problems that could be eliminated with a simple blueprint and/or die change. >:(
Oh well.  It wouldn't be as much fun if anyone could restore these things  :)
« Reply #8 on: August 16, 2011, 05:52:03 PM »
I recently picked up PJ O Rourke's book, "Driving Like Crazy".....and here's what he said about the Philipino Jeep body parts business back in its heyday...This referred to the Sareo Jeepney plant, but I bet MD Juan was not any different...
" The Sareo factory was four enormous , open, dirt floored sheds. To shape body parts the workers use depressions hollowed out of the ground in roughly the desired shape. Floor panels were sawed by hand......."
Elsewhere, he mentions he could have bought a stainless jeep body for $500  in Manilla, that galvanized "owner jeep" bodies were available for $150, chassis for $170, and an entire Toyota pwered 2WD jeep could be had for $2500. At those prices you KNOW work was not quite up to ISO 9000 standards. Today's repop parts are a direct result of that industry, and unfortunately have the same good but not quite right accuracy standards inherited from the 70's when it was more of a kit car thing instead of accurate replacement body parts for restorations.
THe rest of the book is a fun, tho vulgar, read, good for a boring afternoon when you are awaiting oversize permits.... 8-)
« Reply #9 on: August 16, 2011, 05:54:57 PM »
I forgot to mention, if the only problem is the width is off, a long pipe placed over the end of the windshield arm will quickly twist it to the desired position. If you want to do it right, pup a pipe over each arm and bend them inwards the same amount. It'll take about 30 seconds a side. Measuring so you know where to bend it to will take three hours.... ;D
