Author Topic: heater  (Read 4514 times)
Offline RandyA
heater
« on: July 11, 2011, 10:33:15 PM »
does anyone out there have a picture of a heater??? How many different configurations are there? I just pulled mine out and it has dual fans on top of heat exchanger....with a expanded metal shroud over the top too stop debris from entering unit...mine was plumbed with what looked like old steam hose...threaded fittings on one side and hose bib on other....as always ,Thanks in advance....
Re: heater
« Reply #1 on: July 12, 2011, 07:22:13 PM »
Hi Randy,
I know of the Harrison Heater, as it is the type that was installed in my Willys. �There have been others that are more square shaped. �The Harrison is shaped like a kidney I guess. �Below is a photo of mine. �It is disassembled and ready to be cleaned up. �This is a photo of the back side. �This was installed up under the dash on the passenger side.
Re: heater
« Reply #2 on: July 12, 2011, 09:54:03 PM »
Offline Matto
Re: heater
« Reply #3 on: July 12, 2011, 10:12:41 PM »
Here's a picture of the heater on the drivers side of my 54 3B. It has small doors on the front and sides that you open and close to control the heat.
Offline mud pie
  • Once a Marine....
Re: heater
« Reply #4 on: July 13, 2011, 09:36:45 AM »
Wow, my heater looks nothing like those...and I assumed it was OEM because it used the knock-outs on the passenger side of the body.  Mine has a control flap that let's you direct the heat to either the passengers feet or over to the drivers.  It's a square heating coil, maybe 8"x8" motor on top with a shroud covering it.  I'd attach a pic, but the steps needed to attach a pic are maddening...
1953 CJ-3A
Re: heater
« Reply #5 on: July 13, 2011, 09:47:43 AM »
In order to post a pic it must be hosted someplace, like Photobucket.
Offline RandyA
Re: heater
« Reply #6 on: July 16, 2011, 02:36:37 AM »
Thanks all...when I get off this Tub I will try and post some pics...
Offline RandyA
Re: heater
« Reply #7 on: August 13, 2011, 12:50:10 PM »
didnt get to the camera, but disassembled unit   and found out its a... Mobile products model 901 H....must be after market..although mounting bracket seems too be made for firewall bolt pattern...two fans and a pretty good sized heat exchanger on it...
