Author Topic: Sticky lifter  (Read 3978 times)
Sticky lifter
« on: August 11, 2011, 08:19:51 PM »
Anybody have any experience with clearing up a sticky lifter?  I rebuilt the motor but I know I did not get the lifters back in the same holes they came out of.  Adjusted the valve clearance a couple times so I am sure they are right but I still have clatter.  Any suggestions?
Re: Sticky lifter
« Reply #1 on: August 11, 2011, 08:29:33 PM »
If the lifter is sticking it would hold the valve open and the engine would have a slight miss. If the lifters are clicking then the valve clearance is still to loose but, your not going to get all the clicking out of solid lifters.
If they are barely clicking and your sure you have the clearances right don't worry about it, just run it and enjoy the Jeep.
Re: Sticky lifter
« Reply #2 on: August 11, 2011, 09:36:19 PM »
The top of the tappets develop a concave hollow over time. Using a flat blade to set the clearance will result in too much gap. When overhauling the engine the tappets need to be ground flat again.
http://www.g503.com/forums/viewtopic.php?f=4&t=74035
Note the tappet on the left.
Kinda like this illustration of a similar problem setting the gap on worn ignition points.
Re: Sticky lifter
« Reply #3 on: August 11, 2011, 10:10:08 PM »
Carl, I would say it's clicking, I did check the exhaust and it did not pull my hand back to the pipe so I don't think it's missing, seems to run fine. However it does seem pretty loud for a click.
Larry, Carl, do either of you know a way of pulling the tapet end off without pulling the head and valves?  If I could I would put on new ones or grind them.
Also, it seems like the clearance between the valve and tappet changes over a couple of days, this seems like measurement error as you indicated Larry, any suggestions on where to get a round Gage?
Re: Sticky lifter
« Reply #4 on: August 11, 2011, 10:19:48 PM »
I just read that post on the G, what happens if a valve spring is in upside down?
Re: Sticky lifter
« Reply #5 on: August 11, 2011, 11:50:52 PM »
Hmm, should have remembered about the wear on the lifters. It's been to long and if you don't use it you lose it.
Well, you can adjust them by feel. This is not an easy thing to do. Get a good lifter and use a dial caliper to measure the height of it and then turn the adjusting screw one hex and measure it again. Now you know how much the screw will travel with each turn of a hex corner. If you can find out the pitch of the screw you don't have to go through that process.
If you find out that each hex equals say .010" then your ready to start. That is only an example I pulled out of the air, don't use it.
Turn the engine over to get the #1 valves ready to adjust then run the adjuster screw up until there is no clearance and there is a very slight drag to turn the lifter. Then back it off as many hex turns or partial hex turns to get the clearance. Do it on all the valves each in their turn in the firing order when they are free.
This is a ball park method and it will work but it is tricky and you really can't measure the clearance. I don't do this unless I have no other options. The best way is to do a valve job and dress the lifters and valve stems. If your not a real good mechanic or confident in yourself then don't do it.
A valve spring with varying distance coils is for stopping harmonics in the spring. Usually the close coils go to the head as best I can remember. It doesn't change the spring tension being one way or the other.
« Last Edit: August 11, 2011, 11:55:42 PM by Carlsjeep »
Re: Sticky lifter
« Reply #6 on: August 12, 2011, 08:58:28 AM »
Larry, Carl, do either of you know a way of pulling the tapet end off without pulling the head and valves? �If I could I would put on new ones or grind them.
There isn't enough room to get the threaded end out.
Mushroom tappets, on these jeeps, ride slightly offset from center on the cam lobe. That causes the tappet to rotate, to prevent wear on just one spot. It sounds like the concave in the worn tappet doesn't line up perfectly with the valve stem causing intermittent clicking. There's no way to adjust that since the gap changes as the tappet rotates.
Re: Sticky lifter
« Reply #7 on: August 12, 2011, 11:43:35 AM »
Thanks guys, I think I know where this is going.  I'm going to try one last time to minimize the racket without leaving a valve open, that should get me through the rest of the year, then it will be time to pull the head and valves and dress the tappet ends.  I'm assuming I can unscrew the ends without pulling the tappets... right?
Re: Sticky lifter
« Reply #8 on: August 12, 2011, 02:17:31 PM »
I don't know what you mean by unscrewing the ends but if you adjust them as I suggested you can get by until you rebuild the engine. You could buy another engine and build it and then swap yours out. Then either build yours or keep it for a back up.
If you do the reset as I suggested set the clearance a tad loose just to be safe. Just as Larry said the lifters rotate as the engine runs and that rotation tends to make the wear even on the lifter and valve stem. It sometimes even crowns the cam lobes and when you put new lifters in, the cam only lifts in the center of the lobe where it is crowned.
When you rebuild an engine you need to check the cam lobes for wear just as you would the crankshaft. Remember, everything turning and rubbing in the engine is wearing and needs to be checked for being up to specs.
Many people think of an overhaul as valve job, head surfacing, boring, reringing, new bearings and crank work but there is much much more to it if it's done right. Lots more the untrained, inexperienced mechanic will overlook. Even pro's get lazy sometimes and don't do it all.
« Last Edit: August 12, 2011, 02:20:31 PM by Carlsjeep »
Re: Sticky lifter
« Reply #9 on: August 12, 2011, 10:44:26 PM »
Thanks Carl, I think thats exactly what I'm doing, chasing the gremlins left in by someone that should have done a better job.  This motor was just re-bulit this spring, remember the guy who had two crank bearing failures in a week?  Yeh thats this engine.
 I took your advice and adjusted the tappets from the top down.  I took a spare tappet, measured the length, then turned the adjuster 1/2 turn. Measured again, it had moved vertically .012 inches.  Went out and set the no.1 piston at just before TDC, both valves closed and adjusted the tappets up unitl it they just touched the valve, then backed it off 3 flats, or 1/2 turn.  Repeated for all the cylinders.  The noise changed some, but not a lot.  I guess I'm going to have to pull the valve train this winter.  I was hoping I could replace just the adjuster piece of the tappet, and not the whole thing.  Nice thing about winter in Minnesota, lots of time to work on stuff... :o
Re: Sticky lifter
« Reply #10 on: August 12, 2011, 11:35:08 PM »
Yes, I remember your posts about the crank bearings now. Well, maybe you can just pull the engine, pull the head, cam, valves, lifters, etc. Just be sure to check everything real good.
My engine has some clicking in it even after I adjusted the valves but it's not to bad. It has good comp., don't burn oil and has good oil pressure. I think it has been overhauled or exchanged but I have thought about getting another engine to rebuild when I feel it needs it. That way I can spend the time doing it right while still driving the Jeep.
On the other hand since I am 70 maybe it will outlast me ;D.
