Author Topic: old Bosch windshield wiper motor  (Read 2821 times)
Offline BradleyDP
  • Love to play with my Willys
« on: July 20, 2011, 10:03:26 PM »
I have a old Bosch windshield wiper motor. I cant seem to be able to get the wiring right.
Has a on of switch on the back. I wired it direct and motor runs all the time. I know I could just put a switch on my dash. But I want the original switch to control the motor. It seems that the ground  is getting shorted when I use the housing. Switch off, nothing. Switch on, no motor. Wire gets HOT and will smoke.
Called Bosch tech support - NO HELP - to old - they do not keep spec sheets around long.
Do I need to send pictures to help solve this case?
Offline Redrockman
Re: old Bosch windshield wiper motor
« Reply #1 on: July 21, 2011, 10:04:35 AM »
You might check the park switch inside, sometimes the contacts stay closed all the time. Maybe yes, Maybe know ;D ;D ;D
« Reply #2 on: July 30, 2011, 09:33:06 AM »
Another thought might be to insulate the motor housing from the body of the Jeep, if it works fine when you have it in the air, but it grounds out when you put it on the jeep you can test that.  Set it up on your bench like you would if you were mounting it on the jeep, put juice to it and turn it on, then with a multimeter you can test for the grounding out condition.
Offline BradleyDP
« Reply #3 on: July 31, 2011, 06:38:47 PM »
Attached are a few photos of my Bosch windshield wiper motor.
What wire suppose to connect to what? Every way I seem to wire it it shorts out and of course teh switch does not work.
« Reply #4 on: August 01, 2011, 10:22:49 AM »
Have you tried it with the cover off? See if it still runs with the cover off. If it does there's a short internally. If it doesn't there's a problem with the switch mechanisim.
