Author Topic: engine #  (Read 2117 times)
Offline kendak
engine #
« on: July 14, 2011, 08:41:55 PM »
my M38's engine has a internal freeze crack where PO left out antifreeze...I have a good non military engine but need to know if it has chain or gear cam drive ...block serial # J 232366...can any one tell what this engine is out of ?...thanks ....Kent �
Re: engine #
« Reply #1 on: July 14, 2011, 09:27:23 PM »
quickest way to tell if chain or gear drive cam is to look at the front of the timing cover.. If there is a rivet like thing right over the center of the cam gear, that's the clue it is chain drive. If the cover is flat, with no small round bump, it is gear drive. Can't tell you on the number.. I do know the front engine plate will need swapping over if you want to keep the M 38 fuel pump and generator setup no matter which it is.
Offline kendak
Re: engine #
« Reply #2 on: July 14, 2011, 10:44:39 PM »
thanks for the tip ...have [4] engines to pick from & didn't want to waste time tearing down a chain drive...am aware of front cover change....take care ...Kent
Re: engine #
« Reply #3 on: July 15, 2011, 07:28:22 AM »
J 232366 (if correct) is a late 1948/1949 CJ2A engine and would be gear driven.
Offline kendak
Re: engine #
« Reply #4 on: July 15, 2011, 05:04:00 PM »
both M38 engines & the two other spares have a "bump" where the cam center should be ...about .250 high & 1in tapering down to about 1.25 on the timing cover [no rivit] so I assume that all are gear driven...didn't want to waste time tearing the wrong one down....thanks for the help...Kent
