Author Topic: e brake  (Read 2081 times)
Offline RandyA
e brake
« on: July 03, 2011, 01:26:16 AM »
can someone tell me where the bottom clip on e brake cable anchors too ,near the actuating arm?? mine was awol at time of purchase and cannot find big hole...little hole anywhere near brake...ran cable out of firewall along stb side of block, then??? thanks as always..
Re: e brake
« Reply #1 on: July 03, 2011, 06:59:30 AM »
There's a clip on the side of the bell housing and a clamp on the passenger side of the crossmember.
Re: e brake
« Reply #2 on: July 13, 2011, 09:12:22 PM »
Larry,
When the Ebrake is adjusted correctly, how much pull would you see on the cane style handle?  I pull mine about 2 inches and the brake is locked up is that not enough?  Maybe the question is how much play should be in the cable?
Offline RussellL
Re: e brake
« Reply #3 on: July 14, 2011, 02:17:54 AM »
I would say that so long as the e-brake is not dragging when the handle is all the way in, you are good to go.
