My Willys 3A and 3B Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Welcome everyone from the CJ3B!
Willys is a big family.
Home
Help
Search
Downloads
Gallery
Login
Register
3A, 3B, DJ Technical Knowledge Base
"Original"-- Technical Questions, Answers, Observations
Manifold gasket question
« previous
next »
Reply
Print
Pages: [
1
Go Down
Author
Topic: Manifold gasket question (Read 2629 times)
aboyandhisdog
Flatfender Master
on:
June 29, 2011, 09:52:12 PM »
I'm putting my manifolds back on the engine with a new gasket, but...I'm wondering just when you guys like to use copper coat gasket spray. I used it on my head gasket with success, but don't know if I need it on the manifold gasket. What do you think? Is there a 'rule of thumb' that dictates when to use a sealer on a gasket as opposed to just installing a gasket without? Your help is much appreciated!
Logged
rocketeer
Flatfender Master
Support Our Troops.
Re: Manifold gasket question
Reply #1 on:
June 30, 2011, 12:06:45 AM »
No sealer is needed on the manifold gasket.
Logged
http://www.enter.net/~rocketeer/13thaaf/13thmain.html
aboyandhisdog
Flatfender Master
Reply #2 on:
July 01, 2011, 12:28:07 PM »
Thanks, Larry. Is there a consensus as to when an additional gasket sealer is needed vs. using the gasket "as is"? Does it have to do with pressure or moisture, or heat, or what? I'd appreciate any input on this, and I expect I am not alone.
Logged
rocketeer
Flatfender Master
Support Our Troops.
Reply #3 on:
July 01, 2011, 06:51:24 PM »
I use Permatex on just about every gasket except head and manifold. Manifold I never use a sealer as it's not needed and can sometimes cause more problems than it cures. On the head gasket I spray with Copper Spray-A-Gasket. Everything else gets Permatex Form-A-Gasket #2.
Logged
Gunslinger
Flatfender Master
Cj3a, M38A1,
Reply #4 on:
July 01, 2011, 09:33:55 PM »
I tend to use sealer for everything that gets wet, oil or water, the dry stuff seems to be ok without it.
Logged
athawk11
SMF Administrator
Flatfender Master
1949 CJ3A
Reply #5 on:
July 02, 2011, 10:52:10 AM »
I tend to agree with the others. �I am still in re-assembly mode, but I did not use any sealer on the manifold gasket. �I use Permatex #2 on other oil contact gaskets and shaft splines. �I did kick up to Permatex Ultra Blue silicone plus the gasket for the oil pan. �I'm not sue yet if any of it will leak. �I am still at this stage. �(see photo)
Logged
Reply
Print
Pages: [
1
Go Up
« previous
next »
