Author Topic: Heater installation  (Read 2811 times)
Offline DaveB
Heater installation
« on: June 29, 2011, 04:46:50 PM »
Anyone got any tips/hints for removing the plug in the head next to the firewall to install a heater?
Re: Heater installation
« Reply #1 on: June 29, 2011, 09:57:39 PM »
You could use a hole saw that is the same diameter or a touch smaller.
« Reply #2 on: June 30, 2011, 12:15:25 AM »
To remove a pipe plug from the head?
Dave, does the plug have a square head that a wrench would fit over? You could get a 1/2" drive socket that fits over the square head and use a strong-bar to break it loose. I would precede that with an extended soaking with PB Blaster.
Offline DaveB
« Reply #3 on: June 30, 2011, 07:42:54 AM »
Yes, it's a square plug...unfortunately (Ifound out the hard way) it is slightly smaller than a 1/2" drive, and very soft steel! I was reluctant to use heat because I thought I had read somewhere that it was risky around a cast head. Of course to make things more interesting, it is only about an inch behind the #4 plug, and under the cowl. Guess I'll try the PB Blaster. The other method I tried was to run the engine until the head was hot and added liberal doses of liquid wrench....Obviously to no avail!
« Reply #4 on: June 30, 2011, 12:31:46 PM »
Oops.  I'm an idiot.  I should have read the questions a bit closer.  I have "plugs in the firewall"  on my mind as I am trying to remember how the hoses for my heater were run.
 Larry is absolutely right on.  My head plugs had already been removed.  Good luck on your removal Dave.
Offline DaveB
« Reply #5 on: June 30, 2011, 01:32:30 PM »
Thanks for your help guys. The plug has successfuly been removed!! I didn't even deplete the first aid kit much!
