Author Topic: Vapor from breather - probably not good  (Read 3162 times)
Offline 3aJeeper
  • Luvs me a flatfender Jeep!
« on: June 20, 2011, 07:27:29 AM »
After I run the F134 I notice that there is a wisp of vapor (steam??) escaping from the breather on top of the valve spring cover. It's not a lot, but if you look for it you can see it. I'm guessing this is moister where it shouldn't be. I'm hesitant to dig down into the engine but if that's what I need to do, then so be it. Mainly because I'm afraid that I'll find that the engine block is cracked and I need a new engine. �:(
Hopefully just needs a new head gasket. Does that sound plausible?
Also there is white-ish smoke out the back.
1951 CJ3a
F-134 Hurricane engine
Re: Vapor from breather - probably not good
« Reply #1 on: June 21, 2011, 06:44:16 AM »
After I run the F134 I notice that there is a wisp of vapor (steam??) escaping from the breather on top of the valve spring cover. It's not a lot, but if you look for it you can see it. .............
If those are the only symptoms I would just drive it and see how it goes.
Offline Matto
« Reply #2 on: June 22, 2011, 09:53:06 PM »
You may want to check your PCV valve. You can take it apart to clean it out. Here is a link to the CJ3B site that describes the whole system. I had a problem with white foam building up under my oil fill cap. It turned out the previous owner had disconected and plugged the vacume line on the intake manifold to increase vacume to the wipers. I repaired that and cleaned the PCV valve and the problem went away.
http://www.film.queensu.ca/CJ3B/Tech/PCV.html
« Reply #3 on: June 23, 2011, 05:41:22 AM »
Looks like that engine may have a road draft tube instead of a PCV system. Either way it would be a good idea to check the crankcase venting system.
Offline 3aJeeper
« Reply #4 on: June 23, 2011, 08:39:13 AM »
Yes - I think it has the road draft tube. It's this thing here, correct?
« Last Edit: June 23, 2011, 08:39:51 AM by JBCarney »
1951 CJ3a
« Reply #5 on: June 23, 2011, 08:16:15 PM »
Yep, that is a road draft tube. When the vehicle is moving the air flowing over the end of the tube causes a slight vacuum which pulls air in that filter on the valve cover, through the engine, and out the tube. It would be normal for some vapor to exit the filter on the valve cover when the vehicle is stationary since the air flow would be reversed (hot air rises). That engine probably came from a utility series vehicle, some of which did not use PCV systems.
« Reply #6 on: June 27, 2011, 11:30:58 PM »
You might want to check that cap to make sure that air can get through it easily, its a coallesing cap so its supposed to have a mesh screen in it to stop oil vapor from going out., yet it needs to let air in while driving in order to vent out the draft tube. if that is plugged you can get negative pressure in the crankcase and may lose oil out the draft tube.  And when the engine shuts down it should breathe just the opposite way, up the draft tube and out the cap.
