Author Topic: speedometer cable lube  (Read 3629 times)
Offline brotherdavid
« on: May 13, 2011, 06:31:06 PM »
cleaned my speedometer cable and cable housing today and was wondering what to lube the cable with?
Offline p3ferris
Re: speedometer cable lube
« Reply #1 on: May 13, 2011, 06:48:03 PM »
lythium.
« Reply #2 on: May 13, 2011, 07:31:13 PM »
I have always used white lubriplate grease.
« Reply #3 on: May 13, 2011, 08:50:58 PM »
thanks for the info. I'll pick some up.
Offline jamesr
« Reply #4 on: May 14, 2011, 09:02:19 AM »
I used dry graphite.  Use nothing that holds dirt or dust.  Jim
« Reply #5 on: May 14, 2011, 05:49:10 PM »
The dry graphite will gravitate to the bottom of the cable and leave the core high and dry. Also, there is no way for dirt to get into the speedo cable when it is installed in the tranny and speedo.
Even a good lithium wheel bearing grease is better than dry graphite. There is a graphite grease you can get for lubing dead centers in a lathe but I still don't recommend that for speedo cables.
Offline jamesr
« Reply #6 on: May 15, 2011, 09:56:54 AM »
Hmmm, you may have a point.  Jim
« Reply #7 on: May 16, 2011, 07:57:17 PM »
Use lubriplate.
