Author Topic: Air Cleaner  (Read 14020 times)
Re: Air Cleaner
« Reply #15 on: April 29, 2011, 08:35:35 AM »
It's not hard to maintain an oil bath filter. Just be sure to keep the oil up to the correct level and at least once a year flush the element with a solvent.
You may want to check the oil level two or three times a year.
Re: Air Cleaner
« Reply #16 on: April 29, 2011, 07:01:24 PM »
I've worked for an air filter company for 25 years....I sell the stuff. 8-)
Offline jamesr
Re: Air Cleaner
« Reply #17 on: April 30, 2011, 11:37:47 AM »
Just remember the pcv system needs filtered air to the oil fill tube. � Without filtered air it circulates dusty, dirty or whatever is in the atmosphere air �through your engine. Note the original hose is between the oil bath filter and the carb. �Do the same with a paper filter. �Jim
« Last Edit: April 30, 2011, 11:38:59 AM by jamesr »
