Author Topic: Bumpers  (Read 6269 times)
Offline Paddy
  • '49 CJ3A
Bumpers
« on: February 05, 2011, 05:51:24 PM »
Now that I have the 3A down to the frame I'm looking at the bumpers and am trying to decide whether to remove/replace them.  They aren't in horrible condition but they have some bends in them, and I'm not so sure I'm going to be thrilled looking at them when most everything else eventually looks new.  Removing doesn't look too hard, ie cutting the stud rivets but what's the option for replacing the bumpers with something that reproduces an accurate appearance for the stud rivets?
Paul Hackett
Re: Bumpers
« Reply #1 on: February 06, 2011, 08:07:11 PM »
You could use carriage bolts and grind off the square part under the head. The round head would look a lot like a rivet head.
Re: Bumpers
« Reply #2 on: February 07, 2011, 12:56:20 AM »
That's exactly what I did. �Because the carriage bolt was cadmium plated I chose not to paint it (That is a throwback from the aircraft restoration days. �All plated hardware was left unpainted in the assembly of my Jeep. �All component parts were painted separately prior to assembly). �You wouldn't need to leave it unpainted.  The top bolts and front bolts are carriage bolts.  The bottom bolts are hex head bolts because they are not in view.
« Last Edit: February 07, 2011, 12:57:37 AM by calvinhunt »
Re: Bumpers
« Reply #3 on: February 07, 2011, 09:43:04 AM »
If you get really picky on restoring it, someone has suggested in the past to hit the head of the carriage bolts with a hammer prior to installing them.  This would mimic the slight indention on the original rivets.
Of course, someone in the know will just wink at you and reach behind the bumper and feel for the threads of the carriage bolts to see if they are original.. ;)
Offline mud pie
  • Once a Marine....
Re: Bumpers
« Reply #4 on: February 07, 2011, 09:59:55 PM »
I, personally, dislike rivets.  When I ground mine off to replace my front bumper, I replaced them with some Grade 8 bolts.  Bolts, to me, are serviceable, look better, heck, more manly than rivets !   ;D
1953 CJ-3A
Offline RA472A
Re: Bumpers
« Reply #5 on: February 09, 2011, 12:08:46 AM »
The easiest thing may be to use grade 8 cap screws.  You can fill them in with a quick weld and grind to resemble a rivet.  A good hardware store will have them.
Offline Paddy
  • '49 CJ3A
Re: Bumpers
« Reply #6 on: February 10, 2011, 08:09:57 PM »
If I could figure out how to post a photo I would show yo what I found.  Mullins Jeep Parts sells an amazing duplicate called Bumper Gusset special imitation rivet set.  It looks fantastic and basically is a special bolt that bolts on and looks like a rivet.  Maybe it meets all the needs, bolts on, and looks like a rivet.
Paul Hackett
Re: Bumpers
« Reply #7 on: February 10, 2011, 09:56:44 PM »
If I could figure out how to post a photo I would show yo what I found. �Mullins Jeep Parts sells an amazing duplicate called Bumper Gusset special imitation rivet set. �It looks fantastic and basically is a special bolt that bolts on and looks like a rivet. �Maybe it meets all the needs, bolts on, and looks like a rivet.
Those imitation rivets look great but are no where near as strong as a real rivet or even a 3/8" bolt.
Re: Bumpers
« Reply #8 on: February 10, 2011, 10:00:12 PM »
Here they are....
Re: Bumpers
« Reply #9 on: February 11, 2011, 11:32:12 AM »
Wow, how does everyone find stuff like this?!  I am always amazed at the knowledge of everyone here.  Who would have thought...........reproduction rivets!  What do they cost?
Offline Paddy
  • '49 CJ3A
Re: Bumpers
« Reply #10 on: February 16, 2011, 09:10:18 PM »
I think the cost is $25.00 for a set of 8.  Not too bad.
Paul Hackett
