Author Topic: Brake Master Cyl vent or screw ?  (Read 2020 times)
Offline bayo500
  • You bought a what ?....
« on: December 20, 2010, 11:12:13 PM »
The brake m/cyl has a large screw on lid with a small screw in plug in the centre, should this have a fitting and vent hose instead of the plug, the reason i'm asking is after a test run i had fluid bubbling around the copper sealing ring on the lid and it's on pretty tight, do they normally leak or am i causing a pressure build up that should be vented? Thanks.
Re: Brake Master Cyl vent or screw ?
« Reply #1 on: December 21, 2010, 06:32:58 AM »
A master cylinder cap needs to be vented. Normally a CJ-3A cap is vented with a baffle and a small hole. Sounds like you may have a cap from an M-38 where a vent line ran up to the air filter for underwater fording purposes.
« Reply #2 on: December 21, 2010, 11:26:59 AM »
Bob's right, it's probably an M-38 cap. However, you will need to vent it. You can try to find a CJ3A cap or you could replace the plug with a fitting and attach a tube that extends upward at least a foot or more.
Vernco did something similar to add a remote reservoir but it will give you the general idea:
http://www.vernco.com/brakes/id262.htm
Offline bayo500
« Reply #3 on: December 23, 2010, 09:59:57 PM »
Thanks guys I'll sort it boxing day, happy Christmas...
