Author Topic: oil pickup screen  (Read 2287 times)
Offline FrankU
  • 1950 CJ3A... in every corner of the garage!!!
oil pickup screen
« on: December 20, 2010, 05:29:03 PM »
evenin'
the screen in my oil pickup is all torn up.
screen also has a hole, with a grommet around it, about the size of a quarter.
it appears to be by design... doesn't make sense.
why would you put a hole in a filtering screen?
asked Mike over at Kaiser Willys... he was at a loss.
any insight?
where might i find a replacement screen?
metal window screen work?
thanks,
frank
Re: oil pickup screen
« Reply #1 on: December 20, 2010, 05:53:34 PM »
Are you missing the cover that goes over the screen? Normally the grommet (hole) is touching the cover and thereby plugging it so the oil has to pass through the screen. If the screen becomes clogged the suction will pull it up and allow oil to bypass the clogged screen and go through the grommet. It is probably best to replace the entire unit since it is not as simple as it seems.
Offline FrankU
« Reply #2 on: December 21, 2010, 04:28:05 PM »
evenin'
thanks Bob W.
your explanation of operational theory makes perfect sense.
condition of screen just didn't lend itself to coming to that conclusion.
have checked several vendors to no avail.
anybody have a line a new oil pickup?
thanks,
frank
« Reply #3 on: December 21, 2010, 07:35:35 PM »
Give Carl Walck a call, he might be able to help (610) 852-3110. If not, there's more info below.
Here's what it should look like:
http://www.cj-2a.com/parts_list/index.php?load=detail&520
Here's one on Ebay but it's in Vietnam.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300496971965
Here's some more info:
http://www.thecj2apage.com/forums/parts-lost-found_topic12649_post104886.html?KW=oil+float
This guy has NOS but you have to call for a price. He is a good guy to deal with:
WO-630396 Float, oil pan �$POR. NOS.
http://www.debellajeepparts.com/CJ2engine.htm
