Author Topic: Building an alternator bracket  (Read 3467 times)
Offline Zach S
  • Trying to build a 3B!
« on: May 03, 2019, 09:58:04 AM »
The previous owner of my 3B "engineered" a custom alternator bracket that I want to replace.
You can see it (along with the cam gear that wasn't actually attached to the cam). I've already cut it off and all that fun stuff, but want to build something to hold a 1-wire alternator that I picked up a few months ago.
I'd rather build something than use one of those "universal" kits, it would be awesome if folks would share some pictures of how they have this setup.
Re: Building an alternator bracket
« Reply #1 on: May 03, 2019, 10:22:58 AM »
You know there are several options already available.  If I had fabrication skills, I'd also probably just make one too.  The lower bracket just needs to provide enough clearance to allow the alternator to pivot.
Offline Zach S
« Reply #2 on: May 03, 2019, 10:56:51 AM »
Yeah, I've been looking at different options for pre-manufactured ones, I'd like to build my own if possible.
I also found another picture of the fabra-cobbled one that was on there before I cut it off.
« Reply #3 on: May 03, 2019, 11:33:44 AM »
Hi Zach, I took a "universal" bolt together (pos) bracket, cut away all the extra metal and welded up this little beauty..
Offline mtnman37879
  • Plays With Jeeps
« Reply #4 on: May 04, 2019, 12:40:43 PM »
I built this one from scrap. The cast steel part is from a Toyota 22RE engine, the rest is just angle iron. It bolts to the same holes as the generator and uses the stock adjustment bracket. a Delco one wire with a double pulley is a perfect fit.
Offline Zach S
« Reply #5 on: May 06, 2019, 09:21:57 AM »
Awesome! Thanks everyone for the examples.
