Author Topic: headers don`t clear  (Read 4504 times)
Offline ring eye 01
headers don`t clear
« on: January 22, 2016, 01:03:33 PM »
I thought the chevy v6 convertion into my1951 cj3a was going to be fairly straight on by useing parts from one source.I used Advance Adapter motor mounts and headers.The left header has much clearance of frame,right side none and also hits body mount.I took the trans.crossmember bolts out and motor mount bolts out and moved it all to the right.the header would bolt up and clear the frame but the trans. crossmember boltholes stuck outside the frame on the right and the holes and end of the crossmember were inside the frame on the left.I can go back so the crossmember bolts work but can't use my headers.I guess I could take a hammer and beat the header tube until it clears or cut a notch in the frame and weld metal back in.I really don't want to do either.Has anyone had this problem and how did you cure it.18in.of snow outside and wishing I had a solution.Please help  :( :( :(
Re: headers don`t clear
« Reply #1 on: January 22, 2016, 01:10:14 PM »
I wouldn't beat the tubes in. You will lose HP by doing that. I would see if you could rebend them by heating them up.
« Last Edit: January 22, 2016, 01:10:32 PM by garage_gnome »
Offline Jesse
« Reply #2 on: February 01, 2016, 01:59:54 PM »
Go ahead and dent it. A few dings aren't going to matter that much compared to the upgrade with a V6!
Proof:
https://www.youtube.com/watch?v=azPKIjxmmdU
Have Fun,
-Jesse
« Reply #3 on: February 04, 2016, 10:04:19 AM »
Is there any way you can post some photos of the places where you are hitting your frame?  That might help everyone and give you a few ideas.
Without seeing it, here are a few of my suggestions:
1.  You might be able to raise the engine a little and/or drop the transmission some.  *Usually* you try to have about a 4 degree tilt in your motor to the back of the firewall.
2.  Take Nate's advice and try and re-bend the header.  If you are not comfortable with doing that, find a local hot rod shop or old school exhaust shop.  Most are more than happy to help out another hot rodder.  Take photos so they can see what you have.
3.  Depending on how much clearance you need, you can *slightly* dimple the header tubes if you need to.  Yes, this will slow down your exhaust flow, increase backpressure and could reduce your horsepower, but if it is a slight dimple you will probably never notice it.  However, keep in mind every dent adds up.  If you have 1 5/8" primary tubes in your headers, a 1/2" dent could introduce a pretty major restriction.
4.  I would avoid cutting the frame.  Too much weight and torque in the front of the vehicle to be weakening the frame.
5.  Finally, while you are at the hot rod shop just ask them what a custom made header would cost.  You might be pleasantly surprised..
Good luck and keep us posted!
