Author Topic: Filling Holes in Body  (Read 11425 times)
Offline Stich
  • '49 CJ3A
« on: July 01, 2012, 07:43:37 PM »
OK, at this risk of being laughed at, I gotta ask. First off let me say that my Willys is pretty modded already and not going to be a show Jeep. Just a good dependable driver that I can take out in the woods now and then. I'm not looking to win a show but still want it to look good when I'm done. The body has a lot of "extra" bolt sized holes in it and I don't weld. I tried some JB weld on a piece of scrap metal and bonded it from the back side of the hole to see if that would work to fill the hole. I can (after it cures) grind off the excess amount from the front and theoretically have the holes filled just nicely. So, my question is this. Have you tried this method before and does it work out OK?
Flamers go easy on me, I'm new here  :-[
Thanks
Jack
Re: Filling Holes in Body
« Reply #1 on: July 01, 2012, 08:08:11 PM »
The way I understand you are doing it you will have a bunch of little pieces of metal showing where the holes are on the inside of the tub??
If that is acceptable to you it will work fine until you stress the bond somehow, either thru vibration or impact. First the filler will crack at the hole, then the patch will fall off. It might take days, or years to get to that point.
I have seen some bolt holes filled with bolts, then painted. It is a rustic look, but better than holes in most cases. �SOme guys use stainless or chrome bolts like bumper bolts or small similarly shaped bolts.
In the used car biz, aluminum foil tape is applied from the backside, the hole is tapped inwards with a ball pein, and the hole is filled with fiberglass reenforced filler like Kitty Hair or whatever they call it nowadays. �Again, the inside is sorta ugly looking, but you can get the outside to look nice. the same failure ad your JB weld will happen eventually. It may be decades or weeks, depending on how much surface area the KH has to stick to. The really cheeeep used car guys use newspaper slathered with filler to make the patch. I did a Subaru like that once for a buddy and was amazed at how long it lasted....in the  NY rust belt too.. We saved a rotting hulk of a car for a couple more years that way.
Smaller holes can be soldered up with regular acid core plumbing solder.or body solder. It is a little more durable that way but then you have the lead safety issues.
« Reply #2 on: July 02, 2012, 01:38:57 PM »
Stich,
You could ask a co-worker, friend or neighbor if they have a small wire feed welder you could borrow. �It's pretty easy, and fun to fill small holes, once you get the hang of it.
I have heard JB Weld is amazing stuff. �You could stick some in a spot, smooth it, then literally BEAT it up to see if it stays put.  As Bill mentioned, it would probably be fine, as long as you're not concerned about the way it might look on the inside face of the tub and fenders.
I did a few missed holes with bolts.  Especially in my fenders.  I had taken it apart so long ago, it was tough to remember the holes I needed, and didn't need.
« Last Edit: July 02, 2012, 01:42:51 PM by athawk11 »
« Reply #3 on: July 02, 2012, 01:49:41 PM »
If you want to minimize the amount of work and aren't a purist (sounds like not a problem) the hardware stores sell those black plastic hole plugs.  They have the "ribbed" ends which when you push them through the hole the grab it and are secured.  They come in all sizes and are usually in those flat boxes back with all of the misc. fasteners.  You can cut off the plastic on the back side of the hole and they don't really look too bad - just a flat raised bump, and you could paint the color of the jeep.  Not saying this is the best solution, but it is a quick, inexpensive one.
Offline Stich
  • '49 CJ3A
« Reply #4 on: July 02, 2012, 03:06:10 PM »
Stich,
I have heard JB Weld is amazing stuff. �You could stick some in a spot, smooth it, then literally BEAT it up to see if it stays put. �As Bill mentioned, it would probably be fine, as long as you're not concerned about the way it might look on the inside face of the tub and fenders. �
I did a few missed holes with bolts. �Especially in my fenders. �I had taken it apart so long ago, it was tough to remember the holes I needed, and didn't need.
Tim, I do have a 110 wire feed welder. But when filling a 1/2" hole with it do I use something as a backing or just start at the edge and try to fill it from there?
« Reply #5 on: July 02, 2012, 04:00:31 PM »
You have a welder! �Use it! �:)
Flux core or MIG?  You can do it with flux but a MIG set up is easier (to me).
1/2" is pushing it, Ive been lazy and filled up to 1/2". �That and anything bigger, you should make a plug disc and weld it in. �For smaller stuff, get a peice of copper and use that as a backing. �A piece of flatten copper pipe works good. �Then I grind with a wheel just before the surface then switch to a flapper disc to smooth the weld. �I dont know if you can be that good at that point to get away without body filler but I always use a little bit.
Practice on something 1st
« Last Edit: July 02, 2012, 04:12:53 PM by bretto »
Offline Stich
  • '49 CJ3A
« Reply #6 on: July 02, 2012, 04:35:56 PM »
Thanks Brett, it is flux core. I'll start my practicing on some old metal and see how I do. I like your copper backing trick.
« Reply #7 on: July 02, 2012, 04:36:59 PM »
Just the smart mouth in me talking here, but you could ue the bolt holes as pre drilled accessory mounting locations.  That way when you figure out what goes there, the hole is already drilled....not a good idea huh. ;D
Offline Stich
  • '49 CJ3A
« Reply #8 on: July 02, 2012, 06:55:54 PM »
Judging from the amount of "accs" holes in the body and even the hood, I'm thinking this one might have been one of those Tijuana Taxi's    ;D
Offline NoCoWillys
« Reply #9 on: July 04, 2012, 08:42:00 PM »
I've been filling holes in my body all day today.  I have a little flux core welder that is just a bit too powerful.  I have it turned down all the way and still burn through my sheet metal.  Never thought there would be a day I wished for a less powerful welder? Oh well, today was the day.  I found a few tricks that are allowing me to build up the weld as I fill the holes.  I'm going to have to grind down a bunch as a result but it should turn out OK.  Now if I could just find that PO and ask him why he thought it was a good idea to weld in galvanized steel with brass brazing rod to patch the floor...  ;D
'53 CJ3a
« Reply #10 on: July 04, 2012, 09:52:48 PM »
Stich,
On the 1/2" and larger holes, I got some flat head carriage bolts.  I used a bench grinder to shrink the head of the bolt down to the hole size.  The threaded end of the bolt gave me something to hold onto while grinding to size and welding into the hole.  Once the bolt head was welded in, I used a cut off wheel and grinder to cut the threaded part off and smooth the patch.
Works great.
Offline Stich
  • '49 CJ3A
« Reply #11 on: July 05, 2012, 09:24:34 AM »
Good stuff!  ;)
Thanks
« Reply #12 on: July 06, 2012, 12:47:46 PM »
I would go with welding the holes up.  You will end up with a better repair that isn't that much harder to do.  Remember, don't weld or grind for too long in one spot.  You don't want to build up too much heat that will warp the metal around it.  This is especially critical on a large, flat body piece like the hood.  Take plenty of breaks and let the metal cool down.
Good luck!  Something about welding always puts me in a better mood! :)
Offline Stich
  • '49 CJ3A
« Reply #13 on: July 06, 2012, 03:57:39 PM »
Good luck! �Something about welding always puts me in a better mood! :)
Says the guy that knows how to weld  ;)
« Reply #14 on: July 09, 2012, 11:18:02 AM »
Says the guy that knows how to weld �;)
 ;D No, I really wish I DID know how to weld better!  I'm better than I used to be, but far and away from calling myself good.  I just enjoy trying! ;)
Good luck!
