Author Topic: chrome removal  (Read 5464 times)
Offline RandyA
chrome removal
« on: April 24, 2011, 02:04:54 PM »
whats the best way you gentlemen have found too remove the old rust and chrome on the headlight bezels?? I don't have access to a bead blaster...Thanks.....
Offline Matto
Re: chrome removal
« Reply #1 on: April 24, 2011, 06:58:54 PM »
A good wire wheel on a 3450 RPM bench grinder or moter spindle works good for small parts like that. You absolutely have to wear safety glasses because the bristles come off like bullets. A right angle grinder with wire wheel works good on larger stuff.
Re: chrome removal
« Reply #2 on: April 26, 2011, 09:41:45 AM »
Ditto on the wire wheel.  Make sure you wear gloves also as the part can get pretty hot if you are not careful.  You can also take it to a chrome shop and have it chemically stripped.  However, I replaced my chrome rings on my jeep with repro ones from Walcks.  Good quality and fit and they didn't cost too much either. ;)
Re: chrome removal
« Reply #3 on: April 26, 2011, 12:48:59 PM »
And do not breathe the chrome dust. Wear a qualified respirator. While it's never a good idea to breathe in any grinder dust there are three metals commonly found when working on a vehicle that constitute a real toxic health hazard; Zinc, Chrome, and Cadmium.
Offline Matto
Re: chrome removal
« Reply #4 on: April 26, 2011, 09:26:07 PM »
Thanks for the heads up on the chrome dust Larry. I had no idea it was any worse than steel. I know welding galvanized steel produces toxic fumes and I also remember hearing somthing about welding parts that were sprayed with brake cleaner producing Phosgene gas, same stuff they used in WW1 chemical weapons.
Offline RandyA
Re: chrome removal
« Reply #5 on: April 27, 2011, 02:16:57 AM »
Thanks all, I am going too try and de-chrome in the AM...
Offline CRT
Re: chrome removal
« Reply #6 on: May 14, 2011, 08:38:35 AM »
I have cleaned up some slightly rusted chrome parts in the past by using water and SOS braille pads.
Re: chrome removal
« Reply #7 on: June 17, 2011, 01:51:23 PM »
I used a product called FLITZ to polish my chrome, it worked very well and leaves a dark blue lustre.  Mine was not rusted, just a little pitted so I think that makes a difference.
