Author Topic: Disassemble a jeep in three easy steps. Give or ta  (Read 9014 times)
« on: August 03, 2013, 05:44:42 PM »
Okay, you have done your shake down cruises, and are ready to dismantle...
OR, your jeep is so far gone or missing parts you need to drive it, so it is time to disassemble...
(Key "NO Diisassemble" sound bite fromShort Circuit movie about a robot...)
You have already photographed everything, right??
Take out your battery first to prevent bad sparkies. Clean it off and store it in a cool dry place off the ground. If it is a good battery charge it regularly while you have the jeep apart. If it is junk , just save it for a core.
� �Start out by buying a can of PB blaster or Kroil or your favorite break loose rusty parts solution in a can. Soak every bolt you can find with a liberal dose of it. Go crazy. If you shop doesn't smell like the Kroil plant and you can still tell what color your dog is, you haven't used enough. Let it soak for a while. Let the steering wheel soak for a LONG time.. It might help the steering wheel out to remove the nut and soak the wheel itself whre it goes over the steering tube.
� �You have your assorted cardboard boxes and ziplock baggies ready, your notebook and your sharpies, right grasshopper? EVERY single thing you remove you want to photograph, label, bag and tag, and make notes about what you need to do to it.� Believe me you will be glad you did ten years from now. (Ok, a few months from now. if you are quicker than I am. )
First off remove any loose stuff from the jeep. If it still has seats, and a top, they are a great place to start. Keep all the components of a part with the part or in a corresponding baggie.
 Sometimes you can zip tie or wire things like seat brackets to the seat.
You want to dismantle in large chunks. I'd go to the windshield next, and pop the pivot bolts out, while setting aside the whole assembly, wipers, glass, inner and outer frame if it is a 2A frame, in a safe location. You can get back to it and rebuilt the whole assembly later on. (Some prefer to rebuild assemblies as they remove them, I do not as rebuilding costs $$)
« Last Edit: August 03, 2013, 07:46:12 PM by F_Bill »
Re: Just got a jeep? Here's where to start....
« Reply #1 on: August 03, 2013, 05:57:27 PM »
I had to break it up a bit, it is getting long.So you have seats, windshield� and top stashed away.
Next, before we get to far, it might be nice to drain the fluids...Sure makes keeping your floor clean easier, especially if you are the sort of guy that uses a drain pan to empty them into instead of the ground... :D THE block has a drain as well as the radiator, and that will make things a little dryer� compared to just draining the radiator. Recycle appropriately. Used oil sometimes gets saved for my chainsaws (Yup, they are cheapie Poulans, not Stihls that take nice bottled chainlube) and antifreeze gets saved so I can decant off the clean stuff and use it in whatever I am driving that has some coolant leaks like my tractor... If you don't save it for later, the fluids usually can be dropped off at places like Oreillys� or Auto Zone.
The gas tank is another part that should be pulled fairly early on. Keep flames away...and store it in a safe place where sparks and small children can't get near it.� If you have an oldtime radiator shop� you use, might want to bring it down to see what they think of it. If it is obvious junk, save it to keep your sender in for now..and to match it up with the new tank from Walcks.
IF you are doing a frame off complete restoration, the body parts are next. Grille and radiator, hood, and front fenders all get pulled and put in a safe place. A sheet of cardboard or thin plywood on both sides of that valuable radiator can prevent tragedies from happening in storage. Fenders can nest in each other to store, and fit well in the attic or rafters of your garage with the hood.
You've put it off long enough, time for the Steering Wheel. It is so dastardly we even have our own section on pulling the steering wheel, as do most jeep sites. A proper puller, protection for the fragile threaded area while using it, and safe procedures are mandatory. DO NOT try to pull it off by hand unless you hace the nut still loosely on the shaft, as dental work will ensue otherwise.
You can also pup off the steering gear from the frame now.� (For those of us with column shift, you'll have to remove the shift rods too..)Withdraw it downward and forward, you might have to have the left front wheel off and the front end in the air to do it.
Next is the tub....be prepared for battle with all the attaching bolts, and don't forget to disconnect the wiring where needed..
« Last Edit: August 03, 2013, 05:58:13 PM by F_Bill »
Re: Disassemble a jeep in three easy steps. Give or ta
« Reply #2 on: August 03, 2013, 07:21:15 PM »
Once you have the tub attaching hardware removed, check for wire harnesses you will need to disconnect or pull out of the frame. Especially check for taillight stuff, turn signal wires, and rear gas tank sender wires.� Unhook any lines attached to the tub, whether they be fuel, brake, or oil pressure sender hoses. Usually they come apart not far from the place they attach to the tub.
Disconnect your throttle pedal linkage from the pedal. Take out your foot starter pushrod from the starter switch on the starter itself if you have a 3A style starter. If not, you will at least have some wires to remove between the ignition circuit and the starter or the solenoid, if it is attached to the tub. Check for ground wires too, and while you are thinking of ground wires, pull off that pesky ground strap that goes to the motor.
If your jeep still has a speedometer cable that will need to be disconnected from the transmission if 2WD, or transfer case if four wheel drive. Pedals, if stock, can simply be removed by loosening the pinch bolts on the pedal levers and pulling the pedals out of their holes in the floor.
Cane shift owners will want to take off your transmission cover now, and also the top cover on the gearbox that the shifter is part of. Cover the gearbox with a piece of cardboard or a large rag to keep stuff from dropping in.
If you are lucky enough to still have a hand throttle or a governor the linkage will need to be removed or unhooked at the carb. I assume if you have a farm jeep with the three point hitch all that stuff was taken off long ago back when you pulled the seats.
Leave your gages and wiring harness in the tub. You'll take all that out later when you get working on the tub. your tailgate will remove easily so get its weight out of there, stash it safely where it won't get damaged. Rear seat too, if you haven't already� got it out.
« Last Edit: August 03, 2013, 07:22:25 PM by F_Bill »
« Reply #3 on: August 03, 2013, 07:32:08 PM »
Pullling the tub..
Now is the time to call in some favors with your strong buddies. Two of you can do it, but four is better.� Or, you can use a come along to some strong lift point in your garage, or a bucket loader or forklift. If you do use a forklift sort of thing, use it from above the tub, lifting straps hooked to the sides of the tub or around the tub itself. you can bolt to existing holes and use them to hold the straps or� you can loop underneath the floor and around the sides. (Make sure you put the strap between the frame and the tub or you'll lift the whole jeep.) Big rope will also work. Chain will work but it will dent stuff. If you have side grab handles like a WWII jeep has they work great for attaching points. Keep the straps long enough so they do not put too much side pressure on the top sides of the tub and make the classic dent at the wheelhouse tub side seam...
� �� Speaking of denting stuff.. If your tub is rotted badly you might want to bolt or weld in some cross bracing before you remove it so it doesn't fold in half. See some of the bodywork threads for some suggestions where to weld in some square tubing braces.
� � Also before you do the big lift, try lifting each side by hand to see if it is truly unbolted from your jeep. There are some bolts in places you might not expect, like under the fuel tank, that will be obvious if not unbolted.
� �� Everything loose and unhooked??has everyone got good work gloves on so no permanent scarring happens? (Don't ask about why I say this) The guys haven't already downed your keg of beer yet, either? Go for it, lift slowly upwards until clear of the jeep. Then walk it back off the jeep. Some guys just pull the steering wheel and slide the tub up and over the column, but it does add difficulty to the process.
Set the tub down on some sawhorses, or on some tires to keep it off the ground. don't be tempted to fill it with other parts, as the weight can damage the bottom of the tub sides if it is off the frame.
next, chassis dismantling.
« Last Edit: August 03, 2013, 07:37:06 PM by F_Bill »
« Reply #4 on: August 03, 2013, 07:43:38 PM »
Anyone want to write up how you do your chassis dismantling? I would do it in this order myself:
Engine, driveshafts, transmission and transfer, axle assemblies, springs.
I have to call it quits for tonight but if anyone wants to continue be my guest!! :)
Offline corpsman
« Reply #5 on: February 08, 2015, 11:35:18 PM »
this is a great post.  it's kind of funny, because it sounds exactly like what I did, and almost in the same exact order.  the main difference I saw, was when you got to the chassis.  I hit that from a little different angle, but I guess it doesn't really matter.  for some reason, I wanted to pull the engine, transmission, and transfer case last.  I figured I would pull the rear end, springs, wheels, and all as a unit, and I could deal with that later on.  I pulled all the small stuff first, like brake MC, linkages and arms for brakes, and clutch.  then drive shafts, etc, etc, etc.  anyway, good post!
1952 M38
