Author Topic: need your opinions on pan gasket material...  (Read 7146 times)
« on: November 24, 2014, 11:22:31 AM »
I'm going to drop the transmission pan on my Tacoma 3.4l v6 (probably not important) to change the filter and reseal the pan.� Went to order a filter and gasket, and the pan gaskets come in cork, rubber, and cellulose.� Any thoughts on the best way to go would be much appreciated.
Thank you!
Re: need your opinions on pan gasket material...
« Reply #1 on: November 24, 2014, 07:33:17 PM »
Cork gaskets work very well. They seal good on uneven surfaces because the cork compresses at the high spots. The down side is bolt torque. The bolts need to be relatively loose so the cork isn't compressed too much or it will squish out. Loose bolts tend to keep loosening on their own.
Plain rubber gaskets have about the same characteristics as cork.
So I'd select cellulose. The bolts can be tightened just a bit more without causing gasket damage. I also like to coat both sides of the gasket with spray HighTack.
« Reply #2 on: November 24, 2014, 08:10:22 PM »
Hi Tom,
I agree with Bob.� I don't know anything about the size of the pan or bolt spacing on the Toyota transmission, so I go back to the failures and successes I've had with my Willys.�
By far, my favorite oil pan gasket for a Willys is the Felpro cellulose gasket.� I originally tried the cork gasket.� I was conscious of the squish out factor, so I torqued it to about 8 lbs.� It leaked.� I torqued it a bit more.� It leaked more.� I went to the Felpro gasket and haven't had a leaky oil pan since.� This is true on all three Willys. :)
« Reply #3 on: November 24, 2014, 09:12:31 PM »
Interesting...would not have thought cellulose, but cellulose it shall be!   Glad I asked.
Bob, is "high tack" the same thing as the copper coat you might use on a head gasket?  It looks like the PO used RTV sealant and my Haynes says use RTV.  High Tack is the better product?
« Reply #4 on: November 25, 2014, 06:12:56 AM »
HighTack is similar to Coppercoat, but not the same.
ftp://http://www.permatex.com/products-2/product-categories/gasketing/gasket-sealants/permatex-high-tack-spray-a-gasket-sealant-detail
HighTack can also be used to hold a gasket in place for assembly. Spray it on both surfaces, let it dry, and then stick the gasket on.
RTV is generally used without a gasket. When RTV is applied to a gasket it can cause the gasket to slip out of place when the bolts are tightened. The correct type of RTV alone would also be fine for a transmission pan.
« Reply #5 on: November 29, 2014, 03:17:18 PM »
Thanks a lot Bob and Tim.  On a related note, do you know if there is a 3A oil pan gasket available anywhere that isn't cork?
« Reply #6 on: November 29, 2014, 11:24:56 PM »
Tom,
The Felpro gasket.� I've been getting mine on line from Advance Auto.
« Last Edit: November 29, 2014, 11:26:22 PM by athawk11 »
« Reply #7 on: January 16, 2015, 06:20:56 AM »
Got a part number Tim?
« Reply #8 on: January 16, 2015, 11:02:26 AM »
Brett, I happen to have one sitting in a box right here:  Fel-Pro Oil pan set #OS 4350 AD.  It includes the small gasket for the oil pick-up too.  http://www.rockauto.com/catalog/moreinfo.php?pk=126062&cc=1487112
or at Advance:   http://shop.advanceautoparts.com/p/felpro-oil-pan-gasket-set-os-4350-ad/19780710-P?searchTerm=oil+pan+gasket+fel-pro+%23+os4350ad&vehicleIdSearch=534681&isAllVehicle=false
It says it is "molded rubber", but is the only Fel-Pro I could find.  Seems to be a very stout gasket - not like the cork or soft rubber that you see.  Hope this helps.
« Reply #9 on: January 16, 2015, 12:05:30 PM »
Interesting.  It doesn't feel like rubber, but I guess it could have some in it.  The composition is a little hard to describe.  It definitely has a fibrous feel to it.  It doesn't distort when torquing the bolts, which makes it pretty user friendly.
Tom, have you needed to use one yet?
« Reply #10 on: January 16, 2015, 01:51:42 PM »
Negative on that, Tim.  But I do have a leak at the front timing cover seal that I hope to get after in the next week or two.  If I still have some weeping at the oil pan (not sure at this time), then the next project is to R&R the pan gasket.  It has the cork gasket now, and I'm with Bob - it seems like you can't tighten the bolts to speak of without it possibly failing.  I would like to try this Fel-Pro.
