Author Topic: Clutch Grabbing / Jumping  (Read 2821 times)
« on: August 02, 2017, 03:09:51 PM »
I noticed the other day that when I shift to reverse or 1st gear my Jeep jumps (shutters) when I release the clutch. Since it is only 2 years (restoration) old I don't think its a bad disc. I have not tortured the clutch/transmission on hills or pulling.
I think I may have had a leak and oil got on the disc. From what I read I need to replace the disc. Guess you can't get the oil off the disc.
This sound about right to ya'll?
Tumbleweed
Re: Clutch Grabbing / Jumping
« Reply #1 on: August 02, 2017, 07:34:48 PM »
You might take that inspection plate off the top of the bell housing and have a look. It's not unheard of for a clutch or pressure plate to break or loose a spring.
If it looks good I might just try to clean it with some non-chlorinated (green can) brake cleaner. Nothing to lose really....
« Last Edit: August 03, 2017, 12:44:20 PM by 1955CJ-5 »
« Reply #2 on: August 04, 2017, 01:38:43 PM »
Good idea - I'm not really excited about having to put a new disc in.
