Author Topic: Dana 44 Pinion Removal  (Read 2991 times)
Offline Belmondq
  • Money pit...
« on: March 27, 2017, 09:24:59 PM »
Hello, I've removed the yoke and I am now trying to remove the pinion. It doesn't seem to want to budge. Would appreciate any ideas on the best way to remove the pinion. It appears to be in good shape so I'd like to get it out without damaging it.....
« Last Edit: March 27, 2017, 09:25:29 PM by Belmondq »
1952 CJ3A
Offline Belmondq
  • Money pit...
Re: Dana 44 Pinion Removal
« Reply #1 on: March 27, 2017, 09:26:30 PM »
Yoke side
1952 CJ3A
Offline PaulS
« Reply #2 on: March 28, 2017, 06:56:26 PM »
It's been a while...  But I just looked at the parts diagram and it says what I remember.  I don't think there's anything other than the yoke nut holding that in place.  If you tap on the threaded end with a mallet, I think it should move inward (into the diff).
-Paul
« Reply #3 on: March 28, 2017, 07:49:38 PM »
Tap on it with a hammer. Just be sure not to mushroom the end of the pinion. Thread the nut on there to help protect the treads and use a block of hardwood as a cushion between the hammer and pinion.
Offline Belmondq
  • Money pit...
« Reply #4 on: March 28, 2017, 09:49:49 PM »
Thanks! Put the nut back on and used my brass hammer. Came right out.
1952 CJ3A
