Author Topic: Rear Axle Shaft Removal  (Read 3911 times)
Offline Belmondq
  • Money pit...
« on: March 07, 2017, 09:53:28 PM »
And guidance on removing the rear axle shafts would be much appreciated. I believe it's a Dana 44 rear end
1952 CJ3A
Offline LKap
  • Jeep Fanatic
Re: Rear Axle Shaft Removal
« Reply #1 on: March 07, 2017, 10:21:56 PM »
If you do a search over on the 2a page you will get a ton of good tips. I just finished a rear end rebuild. The axles should come out pretty easy unless the bearing or race are rusted.  I used the "brake drum slap hammer technique"
Basically:
1. Using a heavy duty hub puller loosen the brake drum from the axle
2. Put drum GENTLY back on (without engaging taper)
3.  Put axle nut on and spin a couple turns to engage threads
4. GENTLY backslap drum against axle nut and the axle should slowly back out.
This should not require excessive force so as not to damage the drum.  Mine popped right out and I reused my drums without a problem
Offline Belmondq
  • Money pit...
« Reply #2 on: March 07, 2017, 10:51:47 PM »
Crap....  I've removed the drums completely.
1952 CJ3A
Offline LKap
  • Jeep Fanatic
« Reply #3 on: March 07, 2017, 11:02:10 PM »
You are exactly where you want to be!! You're almost done!!! Just LIGHTLY put the drums back in position and thread the axle nuts on a few turns.  Backslap the drum against the nut and they should come right out
Offline Belmondq
  • Money pit...
« Reply #4 on: March 07, 2017, 11:11:54 PM »
Can you explain what you mean by "back slap"?  Sorry, I'm note a real  mechanical fellar.
1952 CJ3A
« Reply #5 on: March 08, 2017, 12:20:50 PM »
Back-slap...
With the drum and nut back on the shaft, use a rubber mallet, or a block of wood and a hammer.� Tap the inside edge of the drum.� This will dislodge the bearing race from the end of the axle.� Once the bearing is loose, the axle should slide right out.
Added a photo...
« Last Edit: March 08, 2017, 12:27:18 PM by athawk11 »
Offline Belmondq
  • Money pit...
« Reply #6 on: March 08, 2017, 09:25:45 PM »
Thanks, I really appreciate the guidance!  I'll give it a try.
1952 CJ3A
