Author Topic: Redi-sleeve install on rear pinion shaft  (Read 6474 times)
« on: July 26, 2015, 03:50:27 PM »
I have a new leak at the rear pinion shaft and have a Redi-sleeve and new oil seal ready to go.  However, have never done a job like this before.  Reading the Haynes and jeep service manual, it looks like I might need a few special tools.  In particular a "yoke holding tool", a "yoke puller", a seal puller", and a "seal install tool".   How necessary are these tools for this job?  I have a universal puller that may work to get the yoke off, but what else do I need to rent to do this job?
If anybody has done this job before, any tips?    Any help would be greatly appreciated.  Thank you!
Re: Redi-sleeve install on rear pinion shaft
« Reply #1 on: July 26, 2015, 05:37:05 PM »
Hi Tom,
Out of the listed tools, I have a seal puller and a universal puller.
I use an electric impact wrench to remove the large nut.  I use a scrap piece of PVC pipe to set the seal.
« Reply #2 on: July 27, 2015, 01:25:34 PM »
Okay, so I have the yoke off.  Not sure how to get the old seal off.  There seems to be a dust cover over it and I'm afraid if I start digging into it with a screw driver I'll damage that dust cover.  Anybody know the best way to get the seal out without damage?  Do I need a seal removal tool?
Also, with the yoke off, there is slop to the pinion shaft.  Is this normal or does it indicate a worn bearing or???
There is a slight groove worn in the shaft of the yoke.  Do you feel that permatex 2 sealant before I slide the redi-sleeve on will be enough to keep this from leaking?  Thank you.
« Reply #3 on: July 27, 2015, 04:50:46 PM »
Well, got er all done.  The parts guy said he thought the yoke was too worn for a sleeve to work.  Decided to try it anyway before buying a new yoke - a $30 gamble.  Haven't driven it yet, probably tonight.
« Reply #4 on: July 28, 2015, 12:54:59 PM »
Take Annie and Sparky along on the test run for good luck!
« Reply #5 on: July 28, 2015, 01:42:22 PM »
Hey Rick,  yes I did, and so far so good!  No trace of a drip at all.  Fingers crossed though - this may only be a temporary victory.  Might get a new yoke on order for the inevitable.
Hope to see you at FCT - any luck on arranging your schedule yet?
« Reply #6 on: July 28, 2015, 02:11:19 PM »
Unless something happens at work I'm go for launch. Keeping fingers crossed!
Offline Skip
« Reply #7 on: January 25, 2016, 11:48:44 PM »
I realize this is an old thread, but how did this work out and did you take any pictures?
Skip
« Reply #8 on: January 26, 2016, 11:13:52 AM »
Hi Skip, no photos - sorry.  The sleeve actually works well but I did find that for the condition of my yoke, it (the sleeve) wasn't long enough to cover all of the worn area on the yoke.  If it had been 1/4 inch longer it would still be working today.  So, it dripped again after a while and I just replaced the yoke with new.  On Amazon the sleeve is about $23 and the yoke is $51 so not that much more to go with a new yoke.
« Reply #9 on: January 26, 2016, 11:51:57 AM »
Skip,
Here is a short "How To" thread I did on another Willys forum.  Photos included...
http://hainesgarage.proboards.com/thread/274/speedi-sleeve-easy-breezy
Offline Skip
« Reply #10 on: January 29, 2016, 10:50:51 PM »
Skip,
Here is a short "How To" thread I did on another Willys forum.� Photos included...
Thanks, looks easy enough.
Skip
