Author Topic: Transmission or gearbox  (Read 3988 times)
Offline DaveL
« on: November 27, 2015, 11:06:30 PM »
my son's 58 3b is having problems. he was shifting out of overdrive and now is not getting anything. No forward or reverse gears.
checked linkage and everything seems to be working. no grinding noises. Was running fine now nothing. should i start by removing overdrive ?
Re: Transmission or gearbox
« Reply #1 on: November 28, 2015, 12:45:51 AM »
Are you sure he didn't accidentally shift the transfer case in to neutral?
Offline DaveL
« Reply #2 on: November 28, 2015, 01:51:13 AM »
yes, I've ne from low to high in all gears and am pretty sure the transfer is engaged
« Reply #3 on: November 28, 2015, 09:12:15 AM »
Do you know the history of that overdrive? How long have you own the Jeep?  Some of the early Saturn OD we're know to have the shift forks break.  Seems odd that it would hold out this long and happen now though.
If you're certain the tranfer case is not in neutral and the throw on all the linkages are all good, then yes, I'd pull the OD out and start there.  Do you have the stock output gear for the t-case that the OD replaces just in case the OD is out of commission?
Keep us in the loop.  Follow up post are eternally helpful to everyone in the future that may come along.
Brett
Offline DaveL
« Reply #4 on: December 01, 2015, 09:58:15 PM »
Removed overdrive today. Found overdrive shift yoke broken inside . have located main drive gear and will install to ensure transmission is OK, while overdrive is overhauled. Will post results.  Thanks
Offline DaveL
« Reply #5 on: December 14, 2015, 03:56:46 PM »
Have installed main drive gear -  transmission seems locked in Rev.  In Rev gear it backs up -  in 1st gear it backs up  -  in 2nd and 3rd when you release clutch, engine stalls out
« Reply #6 on: December 14, 2015, 06:07:24 PM »
Hi Dave,
Check to make sure you have the transmission shift fork in the 1st/Reverse gear slot.
