Author Topic: Clutch Cross Shaft  (Read 2330 times)
Clutch Cross Shaft
« on: September 11, 2015, 04:29:17 PM »
Anyone here rebuilt the Clutch Cross Shaft? One side of mine I can compress in and out, but the other is rock hard..
Any lessons learned would be helpful
Thanks in Advance
Kirk
Re: Clutch Cross Shaft
« Reply #1 on: September 11, 2015, 04:55:49 PM »
The end toward the transmission is spring loaded.
If the tube ends for the pivot ball studs are not worn; it is easily rebuild able.
Measure the distance from the tube to the CL of each lever pivot hole.
Weld the holes shut with mild steel.
Grind smooth.
Re-drill the holes to 5/16" diameter.
