Author Topic: Clutch Pedal Not Returning  (Read 4228 times)
Offline Jimmy Fehr
  • Willis II
« on: August 11, 2015, 10:23:30 AM »
I just bought this CJ-3A and after about a month, when I push the clutch pedal in it stays down. I have to manually pull it back. Is this a weak clutch spring or something else I need to look at?
Re: Clutch Pedal Not Returning
« Reply #1 on: August 11, 2015, 01:25:57 PM »
Sounds like you may have lost your clutch arm return spring.
You can see it pretty clearly in this photo.  It attaches to a body mount on the outside of the frame...
Offline Jimmy Fehr
  • Willis II
« Reply #2 on: August 11, 2015, 01:38:14 PM »
I have the spring. it seems very stiff to push in and then the pedal won't come back. Could the brake / clutch shaft be binding or is this an adjustment?
« Reply #3 on: August 11, 2015, 02:08:29 PM »
It's hard to do by yourself.� Have a friend push in the clutch while you're under the Willys.� The spring can bind on the side of the tub mounting and might need some re-positioning.�
The tube that the clutch rides on sometimes needs to be greased.� There is a grease fitting on the underside of the tube.
The angled support plate that goes from the master cylinder to the inside edge of the clutch tube can also cause a bind.� If bent, or rusty crusty, you might want to straighten it, or add a bit of grease here too.
« Last Edit: August 11, 2015, 02:08:52 PM by athawk11 »
Offline Jimmy Fehr
  • Willis II
« Reply #4 on: August 11, 2015, 03:13:23 PM »
Thanks Tim. I will give that a try.
Offline Jimmy Fehr
  • Willis II
« Reply #5 on: August 12, 2015, 03:54:37 PM »
Tim,
I looked at it last night and I tried greasing, but I think the nipples are no good. One thing for sure, when I push the clutch in, the brake pedal goes with it. probably best to tear it all down?
« Reply #6 on: August 13, 2015, 12:21:01 PM »
Jimmy,
You may just need to disassemble, clean, and lubricate the cross tube.  The grease fitting is replaceable too.
These parts do wear out.  If you have a lot of side to side movement at the peddles, the cross tube, and or, the heavy peddle arms are showing signs of wear.  Even the bracket that holds the tube to the frame can be worn and cause the sloppy peddles.  It is welded, so it does take a little bit of effort to replace.
