Author Topic: carb rebuild  (Read 2969 times)
Offline MikeP
carb rebuild
« on: July 18, 2019, 05:24:30 PM »
so all my parts are done cleaning and im now reassembling the carb and this part has me worried if i can use it or not my original is top and new one bottom this is from the master rebuild kit
1950 willys cj3a
Offline MikeP
Re: carb rebuild
« Reply #1 on: July 19, 2019, 01:59:34 AM »
Also where do these go 1st pic and what goes in the hole 2nd pic and which one to use 3rd pic
1950 willys cj3a
Re: carb rebuild
« Reply #2 on: July 19, 2019, 06:15:19 AM »
#1. The bottom unit screws into the threaded hole in the bowl cover. The top one is incorrect.
#2. If I'm seeing it right, the top piece is useless. Please show me your Metering Rod Tension Spring. It has a square bend.
#3. The brass tube is the main nozzle for a post-war carb. Most kits contain both it and war-time piece.
#4. The aluminum washer is placed over the hole that the Metering Rod passes through on the bowl cover. The rod passes through it as well.
#5. The hooked spring is the Choke Return Spring.
#6. If you are referring to the open threaded port in the throttle body you have two choices. If you have a Vacuum Advance Distributor, that's where the vacuum line hooks up. If not, plug it with a 1/8" NPT fine pipe plug.
#7. Your choice. Either will work fine. The one with the ball arm is for a motor with a belt drive governor.
Some light inspirational reading. Has pictures. http://oldjeepcarbs.com/thread/106/
« Last Edit: July 19, 2019, 06:19:19 AM by scoutpilot »
Offline MikeP
Re: carb rebuild
« Reply #3 on: July 19, 2019, 07:33:54 AM »
thats some great info and this is what im currently dealing with
1950 willys cj3a
Re: carb rebuild
« Reply #4 on: July 19, 2019, 12:07:25 PM »
I hope there are more parts than you show...
Offline MikeP
Re: carb rebuild
« Reply #5 on: July 20, 2019, 08:47:08 PM »
thats all the parts i got left and ive got the carb all back together the best i can but i for the life of me cant figure out this mess
« Last Edit: July 20, 2019, 08:48:29 PM by Roughneck20 »
1950 willys cj3a
Re: carb rebuild
« Reply #6 on: July 20, 2019, 09:40:14 PM »
Here are a couple of pictures, I hope they help...
Re: carb rebuild
« Reply #7 on: July 20, 2019, 09:46:40 PM »
One more....
Offline MikeP
Re: carb rebuild
« Reply #8 on: July 20, 2019, 10:08:39 PM »
those pictures are amazing thanks now i wait till tomorrow to hopefully start her since 1979
1950 willys cj3a
Offline MikeP
Re: carb rebuild
« Reply #9 on: July 20, 2019, 11:35:22 PM »
also whats the proper way to set/adjust the cables
1950 willys cj3a
Re: carb rebuild
« Reply #10 on: July 21, 2019, 06:17:43 AM »
Setting the choke cable: With the choke cable handle all the way into the dash, set the cable as shown. Holding the choke plate fully vertical with the spring pin touching the inside wall, snug the lock screw on the cable itself. Then tighten sheath clamp.
Setting the throttle cable: With the throttle cable handle all the way into the dash, set the cable as shown. Thread the cable through the block. Install the cable lock on the cable leaving about a 1/4" gap between it and the lever.
Offline MikeP
Re: carb rebuild
« Reply #11 on: July 22, 2019, 02:52:10 PM »
this was some great info thank you and i now need to adjust the carb for idle and mixture etc
1950 willys cj3a
Re: carb rebuild
« Reply #12 on: July 22, 2019, 03:25:16 PM »
Do you have a vacuum gauge and a dwell/tach?
Help yourself.
http://oldjeepcarbs.com/board/55/timing
« Last Edit: July 22, 2019, 03:27:25 PM by scoutpilot »
Offline MikeP
Re: carb rebuild
« Reply #13 on: July 22, 2019, 03:48:21 PM »
dont got any of those but i may have my fathers timing light somewhere
1950 willys cj3a
Offline MikeP
Re: carb rebuild
« Reply #14 on: July 22, 2019, 07:24:50 PM »
update i found this
1950 willys cj3a
